Old 11-30-2005, 10:59 PM
sequoia24z's Avatar
Dealer : Bill Wright Toyota Scion
2001 Toyota Sequoia
Last Online: 07-11-2008 03:20 PM
sequoia24z is on a distinguished road.
sequoia24z's Photo Albums
Default brake light on while driving
my brake light has been coming on from time to time.
its the red light that turns on when the hand brake is on.
it turns on quickly and turns off several time i think its sometimes when i brake.
and yes i checked the hand brake is off.
i do need to replace the pads and maybe the rotors but i dont think this is a sensor for that.
thanks in advance for any help
Old 12-01-2005, 05:58 AM
nhparrot's Avatar
Dealer : Rockingham Toyota
1997 Toyota Camry,
2000 Toyota Avalon
Last Online: Yesterday 06:22 PM
nhparrot's Photo Albums
Check your brake fluid level
~Glenn
Old 12-03-2005, 05:46 AM
sequoia24z's Avatar
2001 Toyota Sequoia
it was at min. i filled it up.
im going to wait and see if comes on again it only came on at 3 different times.
have you had this problem or do you think this was the reason.
Old 12-03-2005, 06:24 AM
nhparrot's Avatar
1997 Toyota Camry,
2000 Toyota Avalon
Brake fluid is affected by temperature, but in So. Cal that's probably not an issue, also as your pads wear the level in the reservior gets lower.
~Glenn
Old 12-03-2005, 05:28 PM
sequoia24z's Avatar
2001 Toyota Sequoia
do you think the light was coming on b/c of the brake fluid level.
the light would come on when i tapped the brakes.
Old 12-03-2005, 09:16 PM
LGL002's Avatar
Dealer : Rudy Luther's Toyota
2003 Toyota Camry SE ,V6, Nav,
- Other - 1969 Ford Torino GT,
2004 Toyota Tundra Limited A/C 4X4,
2000 Toyota Tundra SR5,TRD,AC 4X4
Last Online: Yesterday 11:52 PM
Images: 17
LGL002 will become famous soon enough.
LGL002's Photo Albums
Between the fluid normally sloshing around in the reservoir and pressing on the brake pedal (fluid level goes down when that's done, comes back up when pedal's released) your light will come on. Shouldn't happen now that you've topped it off.
By the way there's a float switch inside the reservoir that turns that light on when the fluid's low.
Larry
2003 Camry SE V6 Navigation, Sirius, Lunar Mist
Optima 34R battery
Some people should not be allowed access to tools without books!!!
Old 12-03-2005, 11:05 PM
sequoia24z's Avatar
2001 Toyota Sequoia
thanks
Old 12-04-2005, 08:43 PM
Simias's Avatar
Dealer : Carson Toyota Scion
2001 Toyota Sequoia 2WD SR5,
2004 Toyota 4Runner 4WD V8 Sport
Last Online: 10-25-2009 11:18 AM
Simias is on a distinguished road.
Simias's Photo Albums
yeah..brake fluid in the past has caused the light to go on for a few members, including myself. so just keep an eye on it. next time you take it in for service just have them check everything out to be on the safe side.
Fog light switch mod (non DRL) question nhparrot Electrical & Computer Systems 2 07-29-2006 08:03 PM
Brake Light???? bluesabith7 1Gen-Tundra 1 11-20-2005 05:55 PM
emergency brake light switch pdruffin Brakes 3 01-08-2004 12:45 AM
Converting Cargo to Brake light? unixguru Interior & Exterior 8 08-27-2003 08:46 PM
