Go Back   Tundra Solutions Forum > SUV Forums > 1Gen-Sequoia
1Gen-Sequoia General discussion forum for the first generation 2001 to 2007 Toyota Sequoia.
This is a discussion thread titled "Toyota Navigation System install problem", within the 1Gen-Sequoia forum, part of the SUV Forums category.
Old 01-31-2006, 10:48 PM
Dealer : Atlanta Toyota
2004 Toyota Sequoia
mmvv's Photo Albums
Last Online: 11-04-2007 08:03 PM
mmvv is on a distinguished road.
Red face Toyota Navigation System install problem
Hi all,
I just bought a "like-new" Toyota Navigation system off ebay. Upon my first try, everything seemed to be working just fine, except that the volume control did not work at all. The audio output went to the max and I was not able to lower it down. What is wrong here? Did I buy a wrong system or it is simply defective?
The numbers I see on the unit are Toyota # 86120-0C160 and DW # 468100-0170
If you can help, I would truly appreciate it.
Thank a million in advance.
I would like to add that the model of the Nav unit is E7006. Amazingly, after reading through 8 million posts last night, I learned that this unit actually DOES work with the Sequoia. See this link below:
http://www.tundrasolutions.com/forum...ighlight=e7006 (Unusual Problem)
What is wrong here, guys? Please help me out!
Edit/Delete Message
Old 02-03-2006, 11:12 AM
Dealer : Atlantic Toyota
2003 Toyota Sequoia
dominicancake's Photo Albums
Last Online: 10-11-2008 02:00 PM
dominicancake is on a distinguished road.
Default Re: Toyota Navigation System install problem
The problem is that you purchased a navigation system that works with a digital amplifier and your suv has an analog amplifier. the head unit volume is controled by the amplifier in the vehicles that have digital amplifiers. I'm sorry to say that there is no easy fix for your problem.
Old 02-03-2006, 10:01 PM
2004 Toyota Sequoia
mmvv's Photo Albums
Thank you so much for your response.
If I am replacing the current amp with the digital amp, would it fix the problem? I am worried about the speaker system as well.
Old 02-04-2006, 05:26 PM
2003 Toyota Sequoia
I'm sorry for the slow response.
after checking the diagrams for both systems i advice you not to try to replace the amplifiers and instead find yourself an analog unit. it would be cheapper and no headaches. please check the diagrams and you will see that in order for you to replace the amplifiers you will have to rewire the whole audio system. (not an easy task) the analog system uses two amps and the digital uses only one.
Old 02-22-2006, 09:00 PM
Dealer : Burdick Toyota
2001 Toyota Sequoia
tettedre's Photo Albums
Last Online: 03-23-2008 03:38 PM
tettedre is on a distinguished road.
hello, I' am also interested in purchasing a Toyota Navigation unit for my Sequoia. The unit model is E7001. My Sequoia has the JBL system> Will this System work for me? Also No Speed Sensor harness and No GSP antenna included. Are these hard to find itemsa. wooa Thanks ED
Similar Threads for: Toyota Navigation System install problem
Driveline vibration. nhparrot Engine & Drivetrain 4 01-14-2008 01:13 PM
2001 Toyota Security System question. nhparrot Electrical & Computer Systems 1 01-28-2007 12:50 AM
Grinding while switching from 2wd to 4wd harkeyjt Engine & Drivetrain 11 08-06-2004 06:05 PM
