20' wheels.....?
+ Reply to Thread
Results 1 to 4 of 4
Thread: 20' wheels.....?
  1. #1
    Junior Member xcantuaj is on the right track. xcantuaj's Avatar
    Join Date
    Apr 2002
    Location
    Houson
    Posts
    102
    Liked
    0 times
    Rep Power
    12
    Default 20' wheels.....?
    Will 20inch wheels reduce MPG's?
  2. #2
    Guest rcjunkie is on a distinguished road. rcjunkie's Avatar
    Join Date
    Aug 2005
    Location
    Norcal
    Posts
    507
    Liked
    0 times
    Rep Power
    0
    Default Re: 20' wheels.....?
    It's depends on different factors, diameter, weight, driving style etc.
    As for me the answer is yes. I am averaging 17mpg and doing the 2000 RPM rule. Driving 60-62mph is hard sometimes but to save gas I do it every now and then. My 20" wheels are also about 80-82 lbs inflated.
    In comparison, with my 16" wheels, I was getting about 18.5mpg doing the 2000 RPM rule. Again weight was a factor. My 16" wheels with tires inflated were approx 65lbs each.
    Now both diameters are pretty close; the old 16" Revo tires have a slightly larger diameter because the tire is taller mounted. I used the same driving method; 2000 rpm rule. I performed this on long highway trips from San Francisco CA to Elk Grove, CA and the traffic averaged about 70mph; I was the idiot holding traffic back going 62mph. I am running 295/45/20 vs 275/65/16 (I think, I will have to double-check since my 16" are not installed right now).
  3. #3
    Veteran Member czechm8 is a glorious beacon of light. czechm8 is a glorious beacon of light. czechm8 is a glorious beacon of light. czechm8 is a glorious beacon of light. czechm8 is a glorious beacon of light. czechm8 is a glorious beacon of light. czechm8 is a glorious beacon of light. czechm8 is a glorious beacon of light. czechm8 is a glorious beacon of light. czechm8 is a glorious beacon of light. czechm8 is a glorious beacon of light. czechm8's Avatar
    Join Date
    Sep 2004
    Location
    Clive, IA
    Age
    48
    Posts
    1,705
    Liked
    14 times
    Images
    25
    Rep Power
    152
    Quote Originally Posted by xcantuaj
    1) If you increase weight from the stock wheels, then you might see a reduction in MPG.
    2) If you change overall diameter, then you will have to calculate MPG differently since the diameter has changed. Zero net effect on MPG.
    3) If you increase rolling resistance with new wheels/tires, then you might see a reduction in MPG.
    4) If you put your foot in the excellerator more 'cause you look cooler with new 20's on your ride, then you might see a reduction in MPG.
    05 Sequoia 4x4 Ltd. Phantom Grey Pearl, Weld 20" wheels on Michelin tires, MagnaFlow cat-back, Amsoil fluids, custom 15" overhead DVD system, Eclipse NAV system w/camera, Sirius tuner, HD Radio tuner. HAT tweeters, Scanspeak mids and DLS coaxials, TRU B-2110 and H-1 amps, 13" eD sub, iPod hookup. SilverStar Ultra lamps, Bilsteins all around.
  4. #4
    Junior Member tlpru is on a distinguished road. tlpru's Avatar
    Join Date
    Nov 2005
    Location
    southlake,texas
    Posts
    107
    Liked
    0 times
    Rep Power
    8
    bottom line....
    if you are really concerned about gas mileage....sell the sequoia...
    i have 20's love them....slight reduction im gas mileage. but what the hell....its nothing to worry about...
    trent
Posting Permissions
  • You may not post replies
  • You may not edit your posts
