Go Back   Tundra Solutions Forum > SUV Forums > 1Gen-Sequoia
Old 03-08-2006, 12:51 AM
Dealer : Roseville Toyota Scion
2003 Toyota Sequoia
Last Online: 07-17-2006 02:02 PM
samseq03 is on a distinguished road.
samseq03's Photo Albums
Default Timing Belt and Water Pump Replacement
I have an 03 Limited Seq with 98,000 miles and I am wondering if when did you guys/gals replaced the timing belt and/or water pump.
Sam
Old 03-10-2006, 01:14 PM
bikol-ini's Avatar
Dealer : Carson Toyota Scion
2002 Toyota Sequoia
Last Online: 08-20-2009 12:56 PM
bikol-ini is on a distinguished road.
bikol-ini's Photo Albums
Default Re: Timing Belt and Water Pump Replacement
be prepared to at least 1000.00 dealership, change mine on my LS 400 same motor costs me 200 bucks for parts timng belt and water pump, did it myself , the thing is a lot of it is involve just to reach that part to be replaced,
1981 Toyota Celica GT 486000 mi original engine/tranny with 79 Supra F312 rear
1996 Lexus LS 400 210000 mi and going strong
2002 Toyota Sequoia SR5 4WD 80000 mi too young
Old 04-19-2006, 09:49 PM
Dealer : Avondale Toyota Scion
2002 Toyota Sequoia
Last Online: 01-23-2009 10:06 PM
mmikulak is on a distinguished road.
mmikulak's Photo Albums
How much work is it?
I did mine on my 97 4 Runner V6 and it was a bit of a bitch. Not hard just time consuming. Would you know/say it is about the same?
How many miles do they recommend changing the belt at? 90?? 60??
Mike in Goodyear AZ
07 Camry Hybrid
Color- Desert Sand Mica
04 Lexus RX330
Millennium Silver
Old 04-20-2006, 10:07 AM
celica's Avatar
Dealer : Charlesglen Toyota
2003 Toyota Sequoia
Last Online: 11-05-2009 09:26 AM
celica is on a distinguished road.
celica's Photo Albums
A belt replacement at my dealer is only $370 Canadian = $325 US. The belt itselt is only $97 Canadian. I had them do it when I got a new motor & they only charged me for the belt
Matt
2003 4runner Limited
2003 Sequoia Limited
1989 Supra Turbo
Old 04-20-2006, 10:57 AM
hill8570's Avatar
Dealer : Peterson Toyota
2002 Toyota Sequoia
Last Online: 11-02-2009 08:00 PM
hill8570 is on a distinguished road.
hill8570's Photo Albums
Well, I've only got 70K on my 2002, so I haven't had to cross that bridge yet. However, I plan to get 'er at right at the recommended 90K -- losing a belt on an interference engine is seriously bad mojo.
Old 04-20-2006, 11:25 AM
Sanchez's Avatar
2001 Toyota Sequoia,
2007 Toyota Camry,
- Other - Riding in Style
Last Online: 10-23-2009 03:06 PM
Sanchez is on a distinguished road.
Sanchez's Photo Albums
I am at 81k so I will also be getting this done at 90K
Only I am not going to change out the water pump.
Only the belt replacement.
2001 Sequoia 2WD SR5
Mods:20s wrapped w/ 295/45/20
Borla Dual Side Exit Cat Back Exhaust
JBA Headers
OEM Foglights Install
TRD Drop-In Filter
Old 04-20-2006, 09:20 PM
Chinee's Avatar
Dealer : Ed Morse Delray Toyota Scion
2002 Toyota Sequoia
Last Online: 11-05-2009 11:44 PM
Chinee is on a distinguished road.
Chinee's Photo Albums
Why would you not change the water pump at the same time?
Old 04-21-2006, 12:14 AM
Sanchez's Avatar
2007 Toyota Camry,
NOPE... just the belts..
If the pump is not leaking then it should be good to go...
JBA Headers
TRD Drop-In Filter
Old 11-08-2007, 05:29 PM
Dealer : Ira Toyota of Manchester
2000 Toyota Tundra,
2002 Toyota Sequoia
Last Online: 11-06-2009 03:13 PM
darren_nh is on a distinguished road.
darren_nh's Photo Albums
I recommend changing the timing belt at the book interval of 90K. I had mine done in my Tundra at 93K. I also had the water pump, idler pully, serp belt, thermostat, coolant.....all done. The timing belt is about $35. Nothing except used fasteners went back on and I spent about $250 on parts and about the same on labor.
It would suck to have a water pump with 90K on it reinstalled just to have the bearings fail 5K later. Cheap money for peace of mind.
Old 11-08-2007, 07:05 PM
mral1515's Avatar
Dealer : Vandergriff Toyota
2007 Toyota Tundra,
2006 Toyota 4Runner,
- Other - 1983 Celica Supra
Last Online: 10-05-2009 12:31 AM
mral1515 is on a distinguished road.
mral1515's Photo Albums
Toyota recommends replacing the timing belt every 90k on vehicles modle year 98 and newer, and 60k 97 and older. However the part # for the timing belt are the same for 96 through 2002 4 runners. I think they relized you can go farher than 60k. They are also able to advertise longer maint intervals this way.
There is a lot involved on the V-8 t-belt (a lot of parts to take off). Definatly replace the water pump, t-stat, and serp belt at the same time.
Old 11-08-2007, 09:52 PM
Ray's Avatar
Ray Ray is offline
Dealer : Classic Toyota Scion
2001 Toyota Sequoia
Last Online: 11-06-2009 01:45 PM
Ray is on a distinguished road.
Ray's Photo Albums
I did mine myself at 105K miles. Just a lot of parts to remove, it's time consuming.
I replace my timming belt, idler pulleys, belt tensioner, water pump, thermostat, serpentine belt. I call the dealership around and it would cost me $1000 - $1200.
Old 11-09-2007, 10:54 PM
AVERAGEJOE's Avatar
Dealer : Longo Toyota
2002 Toyota Sequoia Silver SR5 4x4,
2004 Toyota Tundra Black SR5 D/C 4x4
Last Online: 02-17-2009 08:18 PM
AVERAGEJOE is on a distinguished road.
AVERAGEJOE's Photo Albums
90 to about 100 tho. miles is the best time if it goes it will cost a whole lot more to fix all the other damage. And its best to do the water pump also with a new belt it is alot tighter then the old one so it puts more pressure on the pump bearings so most likely it will leak and you will have to tear it all down again
Old 12-04-2007, 01:27 AM
Dealer : Vancouver Toyota and Scion
2002 Toyota Sequoia,
2006 Scion xA
Last Online: 12-07-2007 11:53 PM
t2gibbs is on a distinguished road.
t2gibbs's Photo Albums
Just did the timing belt, tensioner, serpentine, thermostat and water pump at 80k miles. Was advised by a friend to go ahead and replace the pump since I already had access to the part. Would hate having to remove the same stuff just to save a few dollars in parts.
Took me about five hours, but went through the maintenance manual I had thoroughly to make sure I wouldn't miss anything. Didn't even have to set at TDC, just made sure the camshafts did not rotate as I was replacing the water pump and belt. If you are mechanically inclined, I'd rate it a 6 out of 10 for difficulty.
BTW, a friend who worked for a Toyota dealership told me that there is enough clearance between the valves and pistons, that the belt could snap and you could still crank it and not damage the pistons, although I don't recommend trying to find out if it's true..
Old 12-04-2007, 02:35 AM
kathyricks's Avatar
Dealer : Capitol Toyota
1993 Toyota Truck
Last Online: 06-02-2009 12:03 PM
kathyricks's Photo Albums
My experience has been the Toyota water pumps last 150-250K if Toyota brand coolant and distilled water is used. The timing belt idler pulleys are good for 150-250K too (at least for highway type drivers).
So I figure the best overall strategy is to do the timing belt alone at 90K and then
the timing belt again at around 160K and then do the water pump and idler pulley at that time (plus any oil seals that may be starting to leak)
The engines the call for a 90K timing belt replacement interval have a heavier duty type timing belt compared to the engines that have a 60K interval.
Old 12-06-2007, 11:17 PM
williamZ's Avatar
Dealer : Jack Safro Toyota Scion
2003 Toyota Sequoia
Last Online: 11-15-2008 09:35 AM
williamZ is on a distinguished road.
williamZ's Photo Albums My eBay
I just had mine done by the dealer since I just bought my truck with 98,000 miles on it and the belt wasn't done yet. They changed the water pump for me too. I called the service dept and they wanted $475 to just do the t-belt.
