Seq 4x4 a true locking differential?
+ Reply to Thread
Results 1 to 8 of 8
Thread: Seq 4x4 a true locking differential?
  1. #1
    Join Date
    Mar 2006
    Location
    central fl
    Posts
    22
    Liked
    0 times
    Rep Power
    9
    Default Seq 4x4 a true locking differential?
    the sales guy told me all four wheels are locked when you push the 4x4 button. This surprised me b/c the only style i ever see is limited slip 4x4, not true locking. I believe jeep has a true locker, but few others.
    does anyone know for sure?
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member Desertnate's Avatar
    Join Date
    Jun 2004
    Location
    St Louis
    Posts
    119
    Liked
    0 times
    Rep Power
    11
    Default Re: Seq 4x4 a true locking differential?
    Quote Originally Posted by tealboy
    It depends on the model year and which button you have pushed.
    On '01-'03 (I think) models you had an open differential when in 4-high. When you pushed the lever into 4-low, the center differential locked up...represented by the green dot in the center of the little indicator lighting up on the dash. This is how my '01 operates
    On '04 and newer models I believe you have three options. 4-high unlocked for road applications, 4-high locked by using an additional button my '01 doesn't have, and 4-low which I believe locks up by default.
    I may be off on what model year the locking diff in 4-high became available.
  4. #3
    Supporter sequoiasoon's Avatar
    Join Date
    May 2003
    Location
    Long Island, NY
    Age
    45
    Posts
    1,230
    Liked
    2 times
    Images
    8
    Rep Power
    13
    The Sequoia's have OPEN diff's front and rear (unless somebody changed them aftermarket) The center diff has a seperate option to lock or be able run it open for fulltime AWD mode. Sequoia use TRACS to modulate brakes to stop the spinning wheel and apply torque to the other. Sorry no locker for you if stock.
  5. #4
    Junior Member dfunk's Avatar
    Join Date
    Aug 2004
    Location
    Henderson,NV
    Posts
    70
    Liked
    0 times
    Rep Power
    11
    Quote Originally Posted by Desertnate
    I have an 04 and I'm in the same boat as your 01-03 description
  6. #5
    Join Date
    Oct 2004
    Location
    Sterling, VA
    Posts
    30
    Liked
    1 times
    Rep Power
    11
    Quote Originally Posted by dfunk
    I have an '04, it has the center diff lock button. The F/R diffs are open/open.
    The button looks something like this:
    ...X
    (Ignore the dots, i'm not great at ascii art)
  7. #6
    Banned
    Join Date
    Mar 2011
    Location
    Williston, Vermont
    Posts
    1
    Liked
    0 times
    Rep Power
    0
    I think we need to see some used differential pics. of your 4x4 so that we could easily get some idea on true locker of it. I'll wait for it.
  8. #7
    Veteran Member JD and Beastlet's Avatar
    Join Date
    Apr 2008
    Location
    Ottawa
    Posts
    541
    Liked
    84 times
    Images
    19
    Rep Power
    31375
    Quote Originally Posted by AnywhereAT View Post
    ...X
    My '05 has that button too. Open front and rear diffs.
    Does TRAC work on the front axle too?
    Linked by ProPride 3P 1400, stopped by Prodigy, guided by Garmin nüvi 1490 LMT.
  9. #8
    Join Date
    May 2003
    Location
    Long Island, NY
    Age
    45
    Posts
    1,230
    Liked
    2 times
    Images
    8
    Rep Power
    13
    Quote Originally Posted by JD and Beastlet View Post
    Yes.....
    The TRAC works on all 4 wheels by applying the brakes to the spinning wheel in an attempt to transfer torque to the opposite wheel. In most "normal" use scenarios it works well. Really icy, snowy, muddy situations and if your tires aren't real good and goop up easy, not so much.
    Part of that reason is that with the TRAC/ESC it also limits your throttle to try and let the wheels gain grip. One of Tireracks snow tire tests was on best grip/acceleration. Most of the snow tires showed optimal grip for starting/clearing snow was at 45% slip (spin) but the electronic systems limit that to about 8%. That's whey they have the "OFF" button so when you need wheel spin to clear tread it will let you......except that it wil also eliminate your traction control and now you have open differentials with one wheel spinning on front and rear.
    Electronics are good but sometimes you definitely want the mechanical if you plan to be offroad or in poor traction conditions often.
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
