Old 03-28-2006, 02:08 PM
Dealer : Toyota of Des Moines
2002 Toyota Sequoia
Last Online: 01-22-2008 08:42 PM
DAGEAR is on a distinguished road.
DAGEAR's Photo Albums
Default ABS & VSC Systems
Hello,
I recently purchases an 02 Sequoia 4WD limited. I think there is something up with the ABS and or VSC systems.
ABS - ABS light does not light up when engine is started and the ABS does not appear to be operational since tires lock up on gravel with no familiar brake pulsation of ABS brakes.
VSC - With the vehicle in 4WD, I can't disable the VSC system.
Any thoughts on where the VSC & ABS ECU's are located?
Thoughts on how to troubleshoot.
Thanks
Old 03-28-2006, 02:37 PM
nhparrot's Avatar
Dealer : Rockingham Toyota
1997 Toyota Camry,
2000 Toyota Avalon
Last Online: Yesterday 06:22 PM
nhparrot's Photo Albums
Default Re: ABS & VSC Systems
When you start the vehicle does the ABS warning light, VSC TRAC warning light, VSC OFF (TRAC OFF) indicator light, BRAKE warning light and SLIP indicator light goes on for approx. 3 seconds and then go out?
Are there any indicator lights stay on 3 seconds after starting?
~Glenn
Old 03-28-2006, 02:39 PM
2002 Toyota Sequoia
ABS, VSC, VSC lights never turn on either after starting or after 3 seconds.
Thinking that the wires to indicator lights may be unplugged?
Old 03-28-2006, 02:45 PM
nhparrot's Avatar
1997 Toyota Camry,
2000 Toyota Avalon
With the Parking Brake applied does the BRAKE warning light come on?
~Glenn
Old 03-28-2006, 02:56 PM
2002 Toyota Sequoia
No, Brake light never comes on.
Airbag and check engine lights do light upon starting then turn off.
Old 03-28-2006, 03:09 PM
nhparrot's Avatar
1997 Toyota Camry,
2000 Toyota Avalon
Try this
(a) Disconnect the connector from the brake fluid warning
switch
(b) Release the parking brake pedal.
(c) Connect the terminals on the harness side of the level
Warning switch connector.
(d) Start the engine, check that the warning light lights up.
If warning light does not light up, test the bulb or wire harness at the combination meter.
~Glenn
Old 03-28-2006, 03:34 PM
2002 Toyota Sequoia
Glenn just to confirm process and location.
Is connector in step A, located on master cylinder.
Where is combination meter located?
Old 03-28-2006, 03:37 PM
nhparrot's Avatar
1997 Toyota Camry,
2000 Toyota Avalon
step A is the 2 wire connector on the Brake Fluid Reservior.
The Combination Meter is Toyota-speak for the Gauge Cluster.
~Glenn
Old 03-28-2006, 04:44 PM
2002 Toyota Sequoia
Glenn,
A few more q's before I go try this.
1. I have had the access panel underneath the steering wheel removed, is the combination meter accessible from this point or is more disassembly required?
2. Where are the VSC and ABS ECU's located?
Thanks for all your help.
Old 03-28-2006, 05:03 PM
nhparrot's Avatar
1997 Toyota Camry,
2000 Toyota Avalon
1- The Cluster finish panel comes out after removing 2 screws. There are 4 screws holding the combination meter.
2 - What you are looking for is the Skid Control ECU attached to the ABS & VSC Actuator on the passenger side of the engine compartment.
Just a word of note, unless there is something obviously wrong or something simple like burned out bulbs, you will need the repair manual, the electrical wiring diagrams, and some experience in automotive electrical systems to diagnose and repair.
~Glenn
Old 03-28-2006, 05:42 PM
2002 Toyota Sequoia
Glenn,
After researching which bulbs work and which ones don't this is what I have figured out.
-Door Ajar lights & Brake do not work
-None of the ABS, VSC, VSC off, slippery work
-Security, Check Engine, Do.
do you have access to Combination meter and wiring diagrams for 2002 Sequoia. I think I found another thread for the 2003 combination meter.
My background is hobbyist mechanic, design electrical circuits for a living. I was hoping to locate something obvious as you stated. Will keep the forum up to date as to what I find to be the cause.
Even though the ABS & VSC lights do not function, wouldn't a malfunction of either the ABS or VSC systems show up on a scan at a Toyota dealer?
Old 03-28-2006, 09:05 PM
2002 Toyota Sequoia
Glen
Unfortunately found the obvious, someone has REMOVED all the bulbs that are not working.
I am a little irritated at myself, for purchasing the vehicle, from Auction House, but "BUYER BEWARE". I plan to check tomorrow as to what my avenues of recourse are since I did have the understanding from the seller that all systems were functioning. Unfortunately, I have already spent $600 on fluid flushes, rear brake pads.
I will keep you informed. Bright side I can have the combination meter removed in under 5 minutes :0).
What does a subscription cost?
Old 03-29-2006, 05:31 AM
nhparrot's Avatar
1997 Toyota Camry,
2000 Toyota Avalon
Glen
Replace the bulbs, they may have been removed to hide an issue. If you are interested in becoming a TS.com subscriber see > Subscriptions
~Glenn
Old 03-29-2006, 07:55 AM
2002 Toyota Sequoia
Glenn,
I have read the member benefits, just wanted to checkout one item.
As a member would I have access to the Toyota factory service manuals? example, instructions/illustrations on replacing the skid control / ABS ECU?
Next do you know of a good source for this ECU?
Plan to replace the bulbs today.
Old 03-29-2006, 12:48 PM
2002 Toyota Sequoia
Glenn,
Does the on board computer (the one that is scanned) keep a scan history, i.e. last time & date that it was scanned?
Trying to determine who last scanned this vehicle as an attempt to determine who removed the bulbs.
Locker mod? quicksilvr Tacoma 243 05-26-2009 06:31 PM
VSC on 2002 Sequoia pkduffy 1Gen-Sequoia 16 12-21-2005 01:53 AM
Difference in parts: ABS and non ABS dyogim Brakes 3 07-07-2005 12:35 PM
VSC, ABS & VSC Track Off Lights Harry Roemisch Suspension & Axle 6 12-22-2004 08:39 PM
Braking effort with VSC Vs non VSC equipted Tundra's bob259 Suspension & Axle 0 10-28-2004 02:17 PM
