Re: Oversize Wheels and Brake Issues
Celica is correct. If you increase wheel mass, then you introduce braking problems. I also run 20's, but each wheel/tire combo is roughly the same weight as my stock wheel/tire so net effect is zero. It is possible to fit 22's on a stock Sequoia with a very low-profile tire that doesn't exceed about 31.5" diameter, but a 22 could potentially weight much more.
Bottome line........unless your 20's are heavier than your stock wheel, I don't think that is the source of your problem. Don't let the tech talk you into an upgraded brake system if you don't need it. Yes, more braking power is better, but it is very expensive to upgrade.
05 Sequoia 4x4 Ltd. Phantom Grey Pearl, Weld 20" wheels on Toyo tires, MagnaFlow cat-back, Amsoil fluids, custom 15" overhead DVD system, Eclipse NAV system w/camera, Sirius tuner. Hybrid Audio Technologies drivers and DLS coaxials, TRU B-2110 and H-1 amps, 13" eD sub, iPod hookup. SilverStar Ultra lamps.
