Originally Posted by maddogsvolusia
I just put 265/70/17s Revos on my Sequoia, and since they are about an inch larger in Diameter than the Dunlops, my odometer and speedometer are obviously off. I'm about 4 mph slow on the speedometer than actual and about 1/2 mile per 10 miles off actual on the odometer. Can the computer be reprogrammed for tire size using a code reader? I would think the wheel speed sensors are just sending pulses to the main unit, so the unit should be able to be programmed to interpret pulses based on tire size. Just curious. It would be a good way to get another tool in under the radar.
No the computer can not be reprogrammed. you can buy a product called
TRUSPEED Speedo Recalibrator. It can be wired into the signal going to the speedeometer head and will change the readings.
Do a search, it has been discused many times and will work on your 2003 Sequoia.
25 yrs with TOYOTA
