Old 06-06-2006, 03:16 PM
mcmatt's Avatar
Dealer : Classic Toyota Scion of Round Rock
2001 Toyota Sequoia
Last Online: 10-30-2009 11:36 PM
mcmatt is on a distinguished road.
mcmatt's Photo Albums
Default Replacement keys and programming
Just an FYI. Due to a purse being stolen, I went through the trouble of getting new master keys and programming them. The keys from ebay work fine, you just have to make sure and get the correct one for your model.
A WORD of ADVICE: I had more trouble getting the keys cut than anything else. I would recommend getting a simple $2 key blank made of a master key before your keys wear down any more. Over time, the keys get worn and the locks tend to "adjust" a little bit to the key. Putting a freshly cut key in has to realign the locks slightly. Anyway, if you have a cheap key that is cut correctly then you can use it as a master to cut any transponder keys you may have to get down the road.
The programming is easy, it is just a bunch of pedal pushing and inserting keys and waiting for timeouts, etc.
You can get a key off ebay for about $20-$25. Much better than $70 at the dealer. And, yes it is true, if you lose all your master keys (black ones), then you will have to buy a new ECM computer for about $1500 and then program new keys into it. The new ECMs come in auto key program mode, but once there have been some master keys entered, you have to use one to program any more keys. You can program 7 simultaneous masters and then a subkey.
I would also recommend to go ahead and buy an extra transponder key (from ebay or dealer) that you can put away as a master that never gets used. You can use this master to program later. Also, don't keep your working keys in the same place even for a short time.
Old 06-06-2006, 04:20 PM
uirx2002's Avatar
Dealer : GO Toyota
2004 Toyota Sequoia
Last Online: 10-30-2009 06:05 AM
uirx2002 is on a distinguished road.
uirx2002's Photo Albums
Default Re: Replacement keys and programming
I'm going to get on it...however, all models 2004 and newer have to buy the keys from the dealer...they're "dealer restricted." I emailed a vendor on ebay about compatibility with my 2004 and that's what they told me. If you find an ebay'r that says they'll work in your 04/05/06, I'd be skeptical.
Unless someone with a newer model tells me otherwise, I'll assume it is true that they're dealer restricted.
Old 06-06-2006, 04:45 PM
mcmatt's Avatar
2001 Toyota Sequoia
There is one OEM Toyota key that I saw with part # 89785 - 17020. I'm not sure what models it covers though. Good luck to you. Your experience will make a good post. I look forward to reading it.
Old 06-12-2006, 12:35 AM
Dealer : Team Toyota
2001 Toyota Sequoia
Last Online: 03-12-2007 12:20 PM
RuffRyder is on a distinguished road.
RuffRyder's Photo Albums
A friend of mine lost his keys a month ago, service guys made him really unhappy about the price, so they simply decided to just disable the whole immobiliser system somehow. Now his seq starts with regular cheap cut key. They say it's very easy and they do it every time when installing a remote start up system for cold weather
Old 07-11-2006, 11:14 AM
Dealer : Alexandria Toyota
2007 Toyota Sequoia
Last Online: 07-11-2006 11:28 AM
toddcoley1 is on a distinguished road.
toddcoley1's Photo Albums
I just bought a 2001 Seqoia and I'm trying to program an extra master key for my wife. Would you send me the master key programming method?
I tried a method posted at Geocities, but it's not working.
R
Todd
Old 07-11-2006, 11:37 AM
mcmatt's Avatar
2001 Toyota Sequoia
I don't have my manual with me, but this was on ebay. It should work. It is what I remember. Let me know if it doesn't.
1. Place an already programmed Master key in the keyway. (Do not turn on.)
2. Press the Gas pedal 5 times.
3. Press the Brake pedal 6 times.
4. Pull out the key.
5. Insert the new key and DO NOT turn it on.
6. Press Gas pedal just 1 time and wait until security light stops blinking, (about a minute.)
7. Remove the key and Press Brake pedal 1 time. The cycle is now closed.
The programming mode will end after 10 more seconds.
Old 07-11-2006, 10:56 PM
outwest's Avatar
2001 Toyota Sequoia
Last Online: 05-26-2008 03:16 PM
outwest is on a distinguished road.
outwest's Photo Albums
mcmatt you got it right, I just programmed my e-bay key this weekend works great. dealer wanted $80, do it yourself $12, this web site saved me $68, thats why I'am subscriber!
Old 11-25-2007, 08:25 PM
2001 Toyota Sequoia
Last Online: 11-22-2009 10:58 PM
myseq is on a distinguished road.
myseq's Photo Albums
My master key has become worn down. However my valet key is brand new. Can I cut a new master key from the valet key and program the new key using the master while the master is still functional?
Old 11-26-2007, 12:20 AM
mral1515's Avatar
Dealer : Vandergriff Toyota
2007 Toyota Tundra,
2006 Toyota 4Runner,
- Other - 1983 Celica Supra
Last Online: 10-05-2009 12:31 AM
mral1515 is on a distinguished road.
mral1515's Photo Albums
The valet key will not open the glove box, back door or the passengers door. It is keyed only to get in through the drivers door and for the ignition. You also have to have to use a master key to program with.
Master Toyota Tech
ASE Master Tech
Shop Foreman
16 years with Toyota
Old 11-26-2007, 05:29 AM
Dealer : Stevens Creek Toyota
2006 Toyota Sequoia
Last Online: 09-29-2008 12:25 AM
maverick_415 is on a distinguished road.
maverick_415's Photo Albums
Just an FYI that you can buy the key and get it cut for around $70 at the dealer. The cut is very precise because they cut according to vin #. They do not copy another key. Once you have that you can use the programming instructions that came with the key you bought on ebay or you can find the instructions elsewhere on the web. My word of advise is do not have anybody cut this key except the dealer. It can be ruined very easily when somebody else is cutting it. By the way you need one existing master key to program the new key. If you loose your master key you have to get the whole car re-keyed and I think that will cost around $500. So if you are down to one master key like I was take the above action and make another key to avoid the costly repair. The key you make will be another master key.
Old 11-26-2007, 07:33 AM
2001 Toyota Sequoia
Originally Posted by maverick_415 View Post
Just an FYI that you can buy the key and get it cut for around $70 at the dealer. The cut is very precise because they cut according to vin #. They do not copy another key. .... The key you make will be another master key.
Thanks for the responses. I will get another key cut right away. Thank you.
Lost Master keys iriepunk 4Runner 50 01-02-2009 01:00 PM
New Sequoia Owner: Question on Keys uirx2002 1Gen-Sequoia 18 01-12-2007 12:10 AM
Programming Keys For Tacoma 2005 Tiago Tacoma 1 02-18-2006 01:50 PM
Programming a key (Tacoma) nucferr Electrical & Computer Systems 2 06-24-2005 07:23 PM
