  #16 (permalink)
Old 07-13-2006, 07:58 PM
sequoiasoon's Avatar
Dealer : Competition Toyota Scion of Middle Island
2003 Toyota Sequoia,
- Other - 93 Corolla TOTALLED!
Last Online: 11-03-2009 08:17 AM
Images: 8
sequoiasoon is on a distinguished road.
sequoiasoon's Photo Albums
Default Re: Need Help with my MPG
Originally Posted by maddogsvolusia
I just replaced all 4 of my O2 sensors trying to get out of the mixed driving 13s in my 2wd with 265/70/17 Bridgestone Revos. (The front Driver's 02 was a nightmare by the way! Galled threads had to be destroyed and retapped!) Anyway, no improvement. I use a K&N air filter, Synthetic oil, and recently tried NGK V-groove plugs. I also run Primrose injector cleaner in every 3000 miles. I keep the tire pressure at 38 to 40 PSI. My next step is synthetic in the transmission and differential. I seem to have plenty of power, I just can't break 13 mpg in mixed driving or 15 mpg highway. It's not terrible for how nice it rides and all the space, I would just like to do a little better. My 12 gallon car can drive farther on a tank of gas than my 26 gallon Sequoia. hehehe
Your "larger tires" are adding to what you see. Check Tire size calculator you are actually off by 3.4% so you might actually be getting at least .5 more mpg (still sucks). Read some of the threads regarding the K&N and decide accordingly. Your MAF might be contaminated from the oil. It's a crazy cycle but here goes, your K&N flows more air (and dirt) and possibly gets oil on the MAF. MAF does not register airflow correctly, more air makes truck lean, O2 sensors see lean condition and richen mixture accordingly to compensate, extra fuel drops mileage as you see it, extra unburned fuel also heats up 02 sensors more possibly damaging them and the next step downstream the cats (as happened to at least 1 member).
YMMV so read the threads and decide accordingly. My self I had problems with the K&N doing exactly that, caused lean condition and ping as well as my used oil analysis showed a BIG difference in extra dirt levels in my oil when I had it. Loved the sound at full throttle, liked the extra power at high RPM (both taking away from MPG) Long term I'll take cleaner oil and better MPG's. Others on here will dispute the info but that was my documented experiences on 2 vehicles.
Also a many members reported a drop in mileage due to the REVO's. Much better traction in dry and wet as well as off road, they have not been reported to be a "low rolling resistance" tire. Better grip comes with trade off's but most decided it was worth it for performance and safety. I also notice a difference in mileage between my Cross Terrains and my winter snows (Nokian SUV's). The CT's give about 10-15% better mileage in same driving conditions.
  #17 (permalink)
Old 07-13-2006, 10:31 PM
maddogsvolusia's Avatar
Dealer : Bob Howard Toyota
2003 Toyota Sequoia
Last Online: 03-08-2009 07:59 AM
maddogsvolusia is on a distinguished road.
maddogsvolusia's Photo Albums
I do calculate the MPG and mileage compensating for 1 mile every 10 on the odometer because of the larger tires, so I feel my calculations are good. However, I did forget that the oiled K&N filter can gum up the MAF if it came with too much oil. I have never cleaned that. Thanks for the reminder! I will spray it down with some electrical cleaner and report back.
  #18 (permalink)
Old 07-16-2006, 05:52 PM
hootydog's Avatar
Last Online: 05-10-2008 06:23 PM
hootydog is on a distinguished road.
hootydog's Photo Albums
My o2 Sequoia gets pretty much 17 in town to 23 highway. It is a 2wd though.
My friends Range Rover is 4wd and she says it gets 10-12..ouch.
good luck Hootydog
  #19 (permalink)
Old 07-16-2006, 10:45 PM
Tundrav8yamaha's Avatar
Banned
Images: 100
Originally Posted by rmjcvelez
I just traded in my 03 4-runner for a 04 Sequoia-I needed additional towing capacity. The following are my MPG calculations with my new (used-with 18Kmiles) Sequoia:
Without a trailer
City 10.2 MPG
Highway 14.3 MPG (315 miles / 22.1 gallons= 14.25)
Pulling a 4300 lbs. trailer
6.3 MPG over mountains
7.3 MPG on flat straight-away
Something seems way off. I contacted the Toyota Dealership and they say that seems low, but not alarmingly low. I started thinking the electrical braking system on the camper was slightly engaged, but this was checked out by the camper dealership and ruled out.
When buying the Sequoia, I expected my gas costs to go up, however, this is unacceptable for a Toyota.
What should be considered acceptable for my MPG??? Any suggestions on how to conserve gas??? Someone mentioned synthetic oil-any specific brands??
I really miss my 4-Runner!!!
Thanks for all input....
Your figures doesnt seem right
The 2004 Iforce v8 should be getting close to 16/15 city 20/18 hwy
there a few thing's you might want to check number one the maf sensor and clean out the flip door location on top the iforce v8 and clean your injectors could be another area which to look at and or replace your spark plug's and IN line fuel filter located under in the frame.....
Let me know if thats helps
Good luck.
  #20 (permalink)
Old 03-16-2007, 12:46 PM
Dealer : Marina Del Rey Toyota Scion
2005 Toyota Tundra
Last Online: 03-16-2007 07:34 PM
iceplyr is on a distinguished road.
iceplyr's Photo Albums
Just does not make any sense. I had a '75 F250 camper special with a 390ci motor and a factory Holly double pumper. It got 8mpg loaded or unloded. It could haul a 22 foot boot and have an 11 foot capmer in the bed at the same time and still have plenty of power left. (I wish I still had it) So how does a vehilce as technologly advanced as a new Toyota get 1mpg more?
2005 Tundra Double Cab Limited 2WD. Flowmaster "40" Series. Sony Head unit. Sony 100W Amp driving 2 X-Plod 10" speakers.
  #21 (permalink)
Old 03-16-2007, 01:15 PM
dcab03's Avatar
Dealer : Lakeside Toyota
2005 Toyota Sequoia
Last Online: 02-26-2009 12:56 PM
dcab03 is on a distinguished road.
dcab03's Photo Albums
My 05 Sequoia only gets 12 MPG in the city and it has been like this for the 12K miles that I have owned it since it was brand new. I knew it would not get good mileage but like someone else said technology should have this thing getting better mileage than 12. I love everthing else about the truck ; well except for the fact the back window stopped working and I have to bring it in to get fixed.
1998 Chevy Tahoe
2008 Saturn VUE
1993 Acura Integra
  #22 (permalink)
Old 03-16-2007, 03:51 PM
2003 Toyota Sequoia
I cleaned the MAF sensor, and I have been getting a consistent 15 MPG with mixed driving for several months. I also removed the K&N filter and went back to the traditional style filter to prevent the MAF from getting oil coated.
On highway trips without a head wind, I have come close to 20 MPG with 100% highway between fillups.
The truck is so perfect in every other way, so I'm ok with 15 mpg.
  #23 (permalink)
Old 03-23-2007, 04:31 PM
el_madmaster's Avatar
Dealer : Burdick Toyota
2001 Toyota Sequoia,
- Other - 1988 Nissan 300ZX
Last Online: 07-26-2009 07:56 PM
el_madmaster is on a distinguished road.
el_madmaster's Photo Albums
Well. For a while I was averaging 455 miles a tank on the highway. After a while, it dropped down, and my overall range in normal city driving was reduced from bout 350-300. Recently my check engine light went on, and it was the Bank 2, #1 O2 sensor. After getting it replaced, as well as the manifold leak, my MPG has since improved to 468 miles a tank highway and some 370 overall driving - almost better than I have ever seen it.
1988 Nissan 300zx 5sd 71,000 miles
1995 Nissan Pathfinder 4x4 5spd 90,000 miles (sold, frame gone)
2001 Sequoia Limited 4x4 119,000 miles (some electronic issues, manifolds, otherwise solid and not a single rattle woot)
  #24 (permalink)
Old 04-03-2007, 01:19 PM
Dealer : Newark Toyotaworld
2005 Toyota Sequoia,
2005 Toyota Tundra,
2008 Toyota Camry
Last Online: 04-13-2009 02:47 PM
ny_transplant is on a distinguished road.
ny_transplant's Photo Albums
Hi all. I am new to the board after purchasing a 2005 SR5 4x4 w/37k miles. Been lurking awhile and enjoy the wealth of information found here.
My main issue is the gas mileage. On a full tank, the overhead display has consistently shown less than 290 miles when I fill up. I am getting around 12 mpg based on the display.
Spoke to the dealer about the poor mileage and was told that the oxygenated gas is the cause. But can that cause a drop of 20%+ from an expected 15+ mpg mixed driving down to 12 mpg?
I've read about the oxygen sensors, and trying to figure out what condition has to be met for the check engine light to come on due to O2 sensor failure? Does it have to be a complete failure, and could mine just be fouled and need replacing? How do I approach dealer to get this replaced under warranty or should I just go ahead and replace all four?
Thanks.
  #25 (permalink)
Old 04-10-2007, 09:39 PM
Dealer : Longo Toyota
Last Online: 04-11-2007 12:05 PM
rsterbens@socal.rr.c is on a distinguished road.
rsterbens@socal.rr.c's Photo Albums
I have 82,000 miles on a '01 Sequoia. All stock including stock size rims and Michelin radials. Never missed a service or oil change. I also have 2 '00 Tundras. The Sequoia mileage sucks. About 10-11 around town, maybe 16 on a all highway trip. The 2 Tundras get about 3mpg better around town. I find it very hard to believe the guys saying they are getting 17 around town. New math??
  #26 (permalink)
Old 05-28-2007, 01:22 AM
Dealer : Star Toyota
2006 Toyota Sequoia,
1995 Toyota Avalon XLS,
- Other - 1995 Honda Civic
Last Online: 11-27-2007 10:31 PM
06silver is on a distinguished road.
06silver's Photo Albums
My 2006 Sequoia Limited 2WD has been getting 15.3 mpg according to the overhead display. (about 75% highway) I may get 19 or so with highway driving. After reading some of the posts here I see that it is not out of line. I am not surprised at the mileage given the size of the truck, I just wish it did better. Poor mileage has been my only complaint with gas in the Houston area reaching $3/gallon.
  #27 (permalink)
Old 05-30-2007, 12:31 AM
Dealer : Elmore Toyota Scion
2002 Toyota Sequoia
Last Online: 12-28-2008 01:51 AM
Larrison is on a distinguished road.
Larrison's Photo Albums
Goes about along with my experience.
I'm running a stock 02 Sequoia SR, with stock wheels and etc using SoCal's oxygenated regular gasoline. Nothing fancy anywhere. About 65 K miles on the car.
My mileage runs from about 20 mpg of pure highway driving at 70+ mph to around 13-15 in all city streets (no freeway driving on the tank). Little to no trailer pulling, but the long trips include at least 4 in the car, plus gear.
This is my calculated mileage from my receipts at the pump, not off the display in the car
  #28 (permalink)
Old 11-30-2007, 01:36 AM
epoch's Avatar
2001 Toyota Sequoia
Last Online: 10-04-2009 01:43 AM
epoch is on a distinguished road.
epoch's Photo Albums
I have an 01 Sequoia with 99K miles. I trying to get better gas mileage. I've replaced 4 02 sensors, synthetic oil change, all brand new Michelin tires, K&N air filter, gas filter, Lucas fuel injector cleaner, and barely tapping on the gas pedal, yet I'm still getting only 13 mpg in city!!! Help!!!
  #29 (permalink)
Old 11-30-2007, 10:17 AM
indycar89's Avatar
Dealer : Ed Martin Toyota
2002 Toyota Sequoia,
- Other - 06 R1200RT
Last Online: 05-11-2009 12:04 PM
indycar89 is on a distinguished road.
indycar89's Photo Albums
I know I piss people off at stop lights, because i ease away gently. It does take effort to get good fuel millage (all other things being equal). I gotta admit through - it sure feels great to bust off the line or mash the gas. On the highway, my MPG drops pretty quickly at anything faster then 70. At 65ish I can get 20 mpg.
1984 BMW 533i (Metric Mechanic 3.7l with lots of goodies)
2002 Sequoia Limited
2006 R1200RT
  #30 (permalink)
Old 11-30-2007, 04:09 PM
2003 Toyota Sequoia
I did away with the K&N filter and cleaned the Mass Airflow Sensor (MAS), and I improved from 12 mpg to 15 mpg. If I had to quess based on what you wrote, I would say cleaning your MAS would be your next move. You remove it by removing the two screws holding it in the air intake tube and disconnect the electical connector. Then spray it out with your choice of MAS cleaner. I used electrical cleaner from radio shack, but people have said Auto Zone carries a MAS cleaner. I haven't looked for it. The electical cleaner came with a brush on the spray tube that I gently use to clean the resistors.
Tundra Towing MPG TundradudeV8 Towing 134 05-23-2008 02:27 PM
My Tacoma Sport Grueling MPG Test AZRickD Tacoma 9 09-13-2006 10:41 AM
a gas story (i got 20+ mpg today) (i have also gotten 0 mpg before) sequoia24z 1Gen-Sequoia 10 12-12-2005 09:32 PM
What is your Tundra's MPG averaging? - READ ONLY Possum 1Gen-Tundra 558 06-26-2004 07:17 PM
Tripmeter-odometer wrong-better mpg charlie Tires and Wheels 2 04-02-2003 09:07 AM
