Go Back   Tundra Solutions Forum > SUV Forums > 1Gen-Sequoia
1Gen-Sequoia General discussion forum for the first generation 2001 to 2007 Toyota Sequoia.
This is a discussion thread titled "Rear Window stopped working..........", within the 1Gen-Sequoia forum, part of the SUV Forums category.
  #31 (permalink)
Old 10-22-2006, 01:01 PM
Dealer : Toyota Scion of Alameda
2002 Toyota Sequoia
e34ntoys's Photo Albums
Last Online: 07-26-2008 01:05 AM
e34ntoys is on a distinguished road.
Default Re: Rear Window stopped working..........
I thought mine went out too.. took it to the dealer since I'm still under warranty.
Found that the motor is fine.. found that that the rear wiper is slightly off... If the wiper is moved off it's "perch", that stops the window from opening. Try messing with the wiper first before you spend $$$
(just my $0.02)
  #32 (permalink)
Old 11-03-2006, 11:05 AM
Sanchez's Avatar
2001 Toyota Sequoia,
2007 Toyota Camry,
- Other - Riding in Style
Sanchez's Photo Albums
Last Online: 10-09-2008 12:36 PM
Sanchez is on a distinguished road.
Originally Posted by Catman View Post
I finally had some time and fixed mine myself. A new motor was not necessary! I took everything apart as instructed in the TSB. When I took the motor off the mounts I tried the switch and it worked fine. The TSB also instructs to remove the small spring and mounting bracket on the bottom of the actuater, which I did. Put the motor back on and it now works fine. Cost was $0, time was about an hour.
I did just about the same as you.. but did not take the motor off..
JUST took the plastic cover and such off to access the gears/motor.
Took off the spring and bracket and BOOM.. It works fine now.
I did not even remove the battery cable either.
lol
2001 Sequoia 2WD SR5
Mods:20s wrapped w/ 295/45/20
Borla Dual Side Exit Cat Back Exhaust
OEM Foglights Install
TRD Drop-In Filter
  #33 (permalink)
Old 11-03-2006, 01:07 PM
Catman's Avatar
Dealer : Acton Toyota
2004 Toyota Sequoia
Catman's Photo Albums
Last Online: 08-19-2008 06:52 PM
Catman is on a distinguished road.
lol
What's the point of that spring and bracket if it's not needed? Seems like it somehow causes everything to bind.
2004 Sequoia LTD
CarSPIN.net
  #34 (permalink)
Old 11-25-2006, 10:33 AM
66fback's Photo Albums
Last Online: 06-28-2008 03:20 PM
66fback is on a distinguished road.
This forum is great! I also had the rear window not working on my 2001... I spent less then 30 minutes following some of the suggestions, took off the rear window cover, removed the spring and bracket as per the TSB and hit the motor a couple times and it works! Thanks.
David
  #35 (permalink)
Old 11-25-2006, 03:26 PM
Johnnny Rock's Avatar
Dealer : DCH Freehold Toyota Scion
2005 Toyota Sequoia
Johnnny Rock's Photo Albums
Last Online: 07-10-2008 07:59 PM
Johnnny Rock is on a distinguished road.
Send a message via AIM to Johnnny Rock
David
Become Subscriber for a few bucks and get even MORE info!!! Keep this great site going!!! LOL Glad to hear you saved ALOT of cash! Johnnnny
1996 Cobra (White)
1999 Tacoma 4 wheel drive (Purple in Color)
2002 Tundra Limited (Dark Green or Jade In Color)
2002 Chevy Corvette Z06 (Candy Apple Red)
2003 HighLander Limited (Silver In Color)
2005 Sequoia Limited (Phantom Grey)
  #36 (permalink)
Old 11-25-2006, 04:26 PM
Dealer : Lakeside Toyota
2002 Toyota Sequoia
arives350's Photo Albums
Last Online: 01-26-2008 10:09 PM
arives350 is on a distinguished road.
Did this the other day and it works like a charm. My window does kind of clunk, clunk, clunk as it goes up and down, a small price to pay for a working rear window though, and I don't know if it's related to the missing pieces or not. The motion up and down is smooth, it just makes the noise. I guess I'll just turn up the radio when operating it so I can't hear it...
Anyone else having this issue?
  #37 (permalink)
Old 12-04-2006, 10:24 PM
sidwin's Photo Albums
Last Online: 12-05-2006 08:27 AM
sidwin is on a distinguished road.
i just did this and mine does make a weird clunk but i could careless now that the window works.
  #38 (permalink)
Old 01-23-2007, 01:40 PM
Dealer : Koons of Annapolis Toyota
2005 Toyota Sequoia
4motheranne's Photo Albums
Last Online: 01-30-2007 07:53 PM
4motheranne is on a distinguished road.
I have an 05. Rear window stopped operating 1 year later after hardly being used. Withing the 3 years but over on the mileage so not covered. Had them give me the old parts. Parts are shiny and new and it can be seen that window was hardly ever operated. Still had to pay over 1000.00 to fix. Disappointed in Toyota.
  #39 (permalink)
Old 01-23-2007, 07:26 PM
Catman's Avatar
2004 Toyota Sequoia
What? $1000.00! You're kidding right? Most of us fixed this ourselves by just removing a spring and bracket in the assembly. You probably didn't need a motor. That's outrageous.
2004 Sequoia LTD
CarSPIN.net
  #40 (permalink)
Old 05-04-2007, 07:21 AM
Dealer : Legacy Toyota Scion of Union City
2002 Toyota Sequoia
brett-sinclair's Photo Albums
Last Online: 05-04-2007 07:21 AM
brett-sinclair is on a distinguished road.
I have a 2002 with the same problem...
I took it all apart and inspected and reassembled... and it worked.. 4 times..then stopped... removed the motor again and disassembled it..
When I opened the motor, I found the magnet inside was broken...not sure how but I think this was a flaw in design.
Replaced the motor and I am good to go.
  #41 (permalink)
Old 06-08-2007, 09:35 PM
dr427's Avatar
Dealer : Hudiburg Toyota Scion
2003 Toyota Sequoia
dr427's Photo Albums
Last Online: 05-30-2008 11:26 PM
dr427 is on a distinguished road.
I ordered what I thought was the right part off ebay. It wasn't, it must have been a side window. The gear was different, but I took apart the bad one and replaced the gears and connector and now it works great!
It was a little scary, but I was pleased I did it myself and it works all for $40.
  #42 (permalink)
Old 06-08-2007, 11:14 PM
mcmatt's Avatar
Dealer : Classic Toyota Scion of Round Rock
2001 Toyota Sequoia
mcmatt's Photo Albums
Last Online: 07-21-2008 08:56 PM
mcmatt is on a distinguished road.
Thumbs up Re: Rear Window stopped working..........
Mine quit working several times. You can take the panels off to get to the motor and then you can take the motor cover off. It is magnetic and it is tricky. It will jump on you. The rotor of the motor will come out and you can clean the copper contacts around the middle of the rotor with a Dremel and small wire brush attachment. They will look like new. If you put it back together, it will probably work. But it won't work for long. When the carbon builds up on the rotor again, it will stop. The key is to remover the stop/spring just as in the TSB. After you remove this, it will remove the resistance on the motor. Mine has now worked for months. Not a new motor. Mine is an '01. Just FYI.
  #43 (permalink)
Old 06-26-2007, 03:57 PM
avletter's Avatar
Dealer : Mid City Toyota
2005 Toyota Sequoia
avletter's Photo Albums
Last Online: 06-26-2007 04:40 PM
avletter is on a distinguished road.
Originally Posted by czechm8 View Post
The rear window stopped working today in my '05. I guess I'll have to take the TSB to the dealer and have the motor replaced. Thank goodness for warranties!
Our '05 sequoia rear window stopped working along with the rear window defroster. It has been like this since we bought it. Finally took it to the dealer and the manager couldn't get it to work either. Kept it overnight and next day get a call saying it was now working so they are unable to replace the parts since the TSB is for windows that are permanently stuck. I know exactly what's going to happen. The motor won't end up breaking down completely until my warranty is out and I'll have to pay out of pocket. How can they get away with this.
  #44 (permalink)
Old 09-06-2007, 03:36 PM
Dealer : Springfield Toyota Scion
2002 Toyota Sequoia
usrigger's Photo Albums
Last Online: 09-09-2007 07:02 PM
usrigger is on a distinguished road.
Cool Re: Rear Window stopped working..........
My Wife took ours to the stealership today. $90 to tell me the rear window moter needed to be replaced..Then another $600 for the parts and labor.
I told the dealer "Jesse James wore a mask when he robbed people...why aren't you wearing yours?"
Does anyone know where I can get a Rear window motor without gfoing to the stealership?
  #45 (permalink)
Old 09-06-2007, 03:48 PM
Dealer : Phil Bachman Toyota
1997 Toyota Tacoma
browntown3's Photo Albums
Last Online: 10-10-2008 02:38 PM
browntown3 is on a distinguished road.
thanks for posting, i have a feeling mine may go out sometime i never use it
Similar Threads for: Rear Window stopped working..........
Rear window issue lewsterett Electrical & Computer Systems 1 08-26-2006 07:18 PM
Want rear window without slider Ray Kane 1Gen-Tundra 5 05-21-2006 11:32 AM
Vertical sliding rear window on Doublecab? shoprman2 Electrical & Computer Systems 6 10-31-2004 11:51 PM
any problems w/mounting amps in the rear seat with a power rear window?? Agent 409 Audio & Stereo 9 04-22-2004 10:18 PM
