Old 08-03-2006, 08:01 PM
2002 Toyota Sequoia
Last Online: 09-10-2008 11:22 PM
prhugh is on a distinguished road.
prhugh's Photo Albums
Default Remote programming instruction
Hello All,
I have an '02 SR5 and I am having a hard time trying to program the new remote that I purchased. I am following the instructions that came with it but I can not get it to go into the programming mode. Does anyone have any programming instructions or can tell me where I can find some. I am trying to get another reference.
Old 08-03-2006, 10:12 PM
Dealer : Heyward Allen Toyota Scion
2002 Toyota Sequoia
Last Online: 09-28-2009 11:15 PM
kyleh24 is on a distinguished road.
kyleh24's Photo Albums
Default Re: Remote programming instruction
Here are instructions that I found here...and they worked on my 02 limited. Kyle
1. unlock all of the doors in the car, open the driver's side door, and make sure the key is not in the ignition
2. put the key into the ignition and then pull it out without turning it or anything
3. within 40 seconds, lock and then unlock the doors five times using the power lock button on the driver's side door.
4. close the door and then open it again
5. within 40 seconds lock and then unlock the doors five times again using the power lock button.
6. Put the key into the ignition and turn it to the on position (not acc and not far enough to actually start the engine) and then back to the off position, then back to on and back to off.
7. Pull the key out of the ignition
8. If you are successful, after about 5 seconds, the doors should power lock and then unlock on their own. If that doesn't happen then try again from step 1.
9. within 40 seconds, hold down the lock and unlock button simultaneously on the remote for a second. Then release and hold down the lock button for 3 seconds. The power locks should cycle again once on their own. If they don't cycle exactly once, repeat this step from the beginning with the remote again.
10. Repeat step 9 for every remote you want to program. You have to do this with any remotes that were previously programmed because this process essentially resets what remotes the car will respond to.
11. Close the driver's side door to signify that you are done programming the remotes.
Old 08-28-2007, 02:44 PM
Dealer : Folsom Lake Toyota Scion
2007 Toyota Sequoia
Last Online: 08-28-2007 02:44 PM
bmedetsky is on a distinguished road.
bmedetsky's Photo Albums
Worked perfectly on my 2007 Sequoia SR5! Thanks so much!
Old 09-29-2007, 08:46 PM
Dealer : Manhattan Beach Toyota
2001 Toyota Sequoia
Last Online: 09-12-2009 02:16 AM
twistagain is on a distinguished road.
twistagain's Photo Albums
Smile Re: Remote programming instruction
Hi,
I did try this programming instruction for my remote control for my sequoia '01 (SR5) today. Unfortunately, it did not work regardless how many times I tried! About a year ago, I bought an RC in ebay and programmed it by myself. It worked perfectly after a couples of trials. I saved the programming instruction. But now those instructions don't seem to work anymore with an RC that I just bought last week to replace the one I lost this year. For some reason, I could not program this new RC at all??? Even worse, I lost the programming of my existing RC. I think I cleared all the registered codes by accident. Now I have to lock and unlock doors with my key instead of my RC. I am now desperate since don't know what to do next after spending almost a day fiddling with RCs. I even took my car to an car alarm store and asked for help. They said I should take it to a Toyota dealer to reprogram my RCs. I'd wonder if anyone knows what's going on with my car ? did anyone go through this trouble before? Please help!!!
I'd appreciate any help from anyone. Many thanks in advance!
Will twist again until my RCs are fixed!
Old 10-03-2007, 05:57 PM
Dealer : Toyota of Orange
2005 Toyota Tundra
Last Online: Yesterday 05:22 AM
diablito1975 is on a distinguished road.
diablito1975's Photo Albums
Originally Posted by twistagain View Post
Hi,
hi, did you make sure that the new remote fcc# on the back matches your old remote fcc#
Old 10-05-2007, 03:44 AM
2001 Toyota Sequoia
Yes. The FCC# is YQ12BAN on both of my RCs and none of them works with the programming instruction for 2001 toyota sequoia . So it makes me think of something else to do with my car but I can't figure it out at all. Please help again. Thanks!
Old 06-19-2008, 05:49 PM
Dealer : Capitol Toyota Scion
2001 Toyota Sequoia
Last Online: 06-30-2008 02:44 PM
zealot23 is on a distinguished road.
zealot23's Photo Albums
Hi, were you able to program the remote for your 01 sequoia? I have the same year sequoia and cant seem to find the programming instructions.
Old 07-03-2008, 12:53 AM
Dealer : Country Hills Toyota
2006 Toyota Sequoia
Last Online: 07-15-2008 05:27 PM
MrJones is on a distinguished road.
MrJones's Photo Albums
Try this link, they have programming instructions for a 2001. It worked for me, hope it helps.
programyourremote.com
Old 07-03-2008, 01:17 AM
intruder70469's Avatar
Dealer : Northshore Toyota
Last Online: 11-02-2009 10:46 PM
intruder70469 is on a distinguished road.
intruder70469's Photo Albums
Thanks
Old 03-06-2009, 07:18 PM
Chamoru's Avatar
Dealer : Toyota of Vacaville
1999 Toyota Avalon
Last Online: 11-17-2009 06:35 PM
Chamoru is on a distinguished road.
Chamoru's Photo Albums
Thanks, this worked for my supervisor's '02 Sequioa SR5. On side note, this is the same procedures I used for my '99 Avalon XLS; wondering if it's the same across all Toyota models...?
Carl
2000 tundra securikey remote programming ccscorpion200 Electrical & Computer Systems 11 04-15-2009 09:47 AM
Programming New Remote Transmitter(s) on Port Installed Keyless Entry System bill99gxe 1Gen-Sequoia 18 02-18-2009 01:36 AM
Anyone knows how to program the factory alarm carloslopez63 Tacoma 17 04-11-2006 12:24 AM
'02 Remote Programming Questions Ando140 1Gen-Tundra 18 12-09-2005 10:52 PM
remote programming sequoia24z Electrical & Computer Systems 2 12-07-2005 03:38 AM
