Old 10-16-2006, 03:13 PM
Dealer : Red McCombs Toyota
2001 Toyota Sequoia
Last Online: 09-03-2009 06:13 AM
Aeroflip is on a distinguished road.
Aeroflip's Photo Albums
Default driver side power mirror
Having problems with my 2001 sequoia's driver side side mirrors. It just started making a humming sound like the motor keeps running. The only way to keep it off is to stick a piece of paper to keep switch between on and off. Has anyone else had this problem? I downloaded the "how to take apart stuff" from the site, but i could not find the side mirror part. Does anyone have any suggestions on what could be the problem? and how to fix. Any info would be appreciated....
2001 Toyota Sequoia Limited
Royce
Old 10-16-2006, 08:52 PM
Johnnny Rock's Avatar
Dealer : DCH Freehold Toyota Scion
2005 Toyota Sequoia
Last Online: 09-22-2009 05:08 AM
Images: 1
Johnnny Rock is on a distinguished road.
Send a message via AIM to Johnnny Rock Johnnny Rock's Photo Albums
Default Re: driver side power mirror
Royce
Are you talking about the electric side view mirror adjustment motor? (The motor that moves the glass around within the side view mirror housing) OR are you talking about the electric motor that pulls the two side view mirrors in for when you go threw the car wash or pull into a tight parking spot? Where are you sticking the piece of paper in at? Johnnny
2004 Ford Lightning (Sonic Blue)
2003 Cobra with LOTS of work : ) (BLACK)
1996 Cobra (White)
1999 Tacoma 4 wheel drive (Purple in Color)
2002 Tundra Limited (Dark Green or Jade In Color)
2002 Chevy Corvette Z06 (Candy Apple Red)
2003 HighLander Limited (Silver In Color)
2005 Sequoia Limited (Phantom Grey)
Old 10-26-2006, 10:09 AM
Dealer : Palm Beach Toyota/Scion
2001 Toyota Sequoia
Last Online: 04-17-2009 04:48 PM
Magaiver is on a distinguished road.
Magaiver's Photo Albums
Im having the exact same problem with my 2001 Sequoia Limited, the electric motor that pulls the two side view mirrors in is making a humming sound like the motor keeps running. Any Clues on how to fix it?
Old 11-20-2006, 02:32 AM
2001 Toyota Sequoia
Hello guys, i haven't posted in a while... still have problems with the power side mirror. It is the motor that pulls both sides in, not adjust the mirrors. I stick a piece of paper at the swith button at the center console.... If anyone has suggestions, please help... I was wondering if the problem is at the switch or at the motor itself... Thanks in advance
Old 02-07-2007, 08:38 PM
Dealer : Metroplex Toyota
2001 Toyota Sequoia
Last Online: 02-14-2007 09:13 AM
One Degree is on a distinguished road.
One Degree's Photo Albums
did you ever find a real fix for your mirror? Mine just started doing the same thing. I pulled the switch out and it stopped making the noise but now my mirror is a little floppy. I dont know if the switch is bad or if there is something wrong with my mirror. I never use the retract option but I would like to have it functional.
Old 03-06-2007, 11:50 PM
Dealer : Regency Toyota - Vancouver
2001 Toyota Sequoia
Last Online: 05-12-2007 11:42 PM
stringaling is on a distinguished road.
stringaling's Photo Albums
Hi -- another 2001 Sequoia... with driver side power mirror that started acting up today... the ticking is really getting annoying!!
Old 09-13-2007, 12:10 AM
Dealer : Toyota Marin
2001 Toyota Sequoia
Last Online: 08-23-2009 03:57 PM
ebriese is on a distinguished road.
ebriese's Photo Albums
It's an epidemic! Mine (2001 Sequoia) just started doing the same thing, out of the blue. This afternoon, it was fine...this evening, it was running nonstop. Anybody have any thoughts about what is wrong?
Old 09-14-2007, 07:35 PM
Dealer : Toyota of Keene
2003 Toyota Sequoia
Last Online: 11-13-2009 10:44 PM
Images: 3
gregc is on a distinguished road.
gregc's Photo Albums
I would start by testing the switch. First things first. I'm sure the test specs are on TIS and in the factory service manual.
If you can confirm that the switch is OK then you need to look at why the mirror motor is cranking when it shouldn't be. There must be some sort of a limit switch or stop-switch somewhere. I haven't taken the mirror assembly apart to see what's in there, but I'm sure the mirror control is set up to stop when a limit switch is reached.
Given mirror switch's location (and inherent abuse) I'd *almost* pick up a new mirror control switch just because it's so likely to be the problem...if you replace the part that is most likely causing the problem you can save yourself several hours of troubleshooting.
Good luck,
Greg C
Old 10-20-2007, 01:43 PM
Dealer : Lakeside Toyota
2002 Toyota Sequoia
Last Online: 01-26-2008 11:09 PM
arives350 is on a distinguished road.
arives350's Photo Albums
Mine started doing this as well. It turns off if I jiggle the mirror fold switch, but then comes back on every time I start the car. I disconnected the mirror switch unit, which solves the problem, and managed to take it apart, but there was no visible defect. Put it back together and plugged it in, and the problem is still there. I went to the dealer and they want $140+ for a new switch...yeah right. So if anyone knows a source for the switch cheaper could you let me and everyone else know?
Thanks
Old 02-16-2008, 01:47 AM
2001 Toyota Sequoia
My power mirror problem was definitely the switch. My dealer swapped it out for a good one from another vehicle and it solved the problem immediately. Though they want $165 for a new one, I decided that having the power folding mirrors operate properly was worth it. Especially if I keep my Sequoia for several more years.
Old 02-16-2008, 04:02 AM
el_madmaster's Avatar
Dealer : Burdick Toyota
2001 Toyota Sequoia,
- Other - 1988 Nissan 300ZX
Last Online: 07-26-2009 07:56 PM
el_madmaster is on a distinguished road.
el_madmaster's Photo Albums
Last march, my power fold left mirror stopped working... thankfully it is obviously within arm's reach and the passenger side still works fine. Interesting it seems to be a fairly common problem. This feature, aside from the rear window, seems pretty trick, and I have had several people comment on how nice it is (for an 01, at least).
1988 Nissan 300zx 5sd 71,000 miles
1995 Nissan Pathfinder 4x4 5spd 90,000 miles (sold, frame gone)
2001 Sequoia Limited 4x4 119,000 miles (some electronic issues, manifolds, otherwise solid and not a single rattle woot)
Old 09-02-2008, 03:17 PM
2003 Toyota Sequoia
Last Online: 09-06-2008 06:49 PM
rslobe is on a distinguished road.
rslobe's Photo Albums
I have a 2003 Sequoia Limited and am having a problem with the right side mirror. It doesn't close when I press the switch. Left (driver's) side is fine. I can hear the motor for a brief second. I had it in to the dealer for something else and they said they "cleaned up the switch" and it worked again for a brief period. I thought they meant AT the mirror, not the interior switch. When I wiggle the switch a bit I can sometimes get it to retract. So..is there a way to get under the oval plate that covers the mirror switch, and the mirror angle switches (which function fine)? Can you just pry that black plate up? Bob
Old 09-03-2009, 10:36 PM
Dealer : Blackwell-Baldwin Toyota
2004 Toyota Sequoia
Last Online: 09-05-2009 11:14 PM
two leg commute is on a distinguished road.
two leg commute's Photo Albums
Same problem as above, 2004 Limited, any idea what the part number is for the switch? I pulled the fuse for now....... Any further insight? It's the driver side mirror, folding motor, seems to run to a limit, then pause.... and try again..... repeat then rinse???
Power window connector Front driver's side thesid Corolla Matrix 1 01-26-2007 11:55 PM
Toyota 4Runner Offers Winning Blend of Capability, Comfort, Power, Safety and Style TS Support Toyota, Scion & Lexus News 0 09-20-2006 11:43 PM
Toyota Highlander Gets New Safety System For 2007 TS Support Toyota, Scion & Lexus News 0 09-20-2006 11:25 PM
2007 Lexus GS 450h Sport Sedan Establishes Performance Hybrid Segment TS Support Toyota, Scion & Lexus News 0 09-12-2006 09:01 AM
CIPA Rearview Mirror Power issue SpectraBlue7 1Gen-Tundra 1 10-08-2005 07:09 PM
