Old 10-20-2006, 06:29 PM
bikol-ini's Avatar
Dealer : Carson Toyota Scion
2002 Toyota Sequoia
Last Online: 08-20-2009 12:56 PM
bikol-ini is on a distinguished road.
bikol-ini's Photo Albums
Default File a complaint to NHSTA regarding VSC/ABS Skid control ECU failure
hi, did somebody file a complaint to NHSTA regarding this skid failure failing and making your vehicle uncontrollable due to sudden cutting off or preventing you from accelerating, I suspect that this is also in conjunction with the quite a while TSB regarding upgrading your brake caliper and rotor, thus having this upgrade throws off the syncronisity of the old brake/caliper combo versus the newer brake upgrade, so for the skid ecu to see a newer upgrade the skid vsc ecu should be reflashed or reprogram or un upgrade of the skid ecu, this is just my opinion after reading all the complaints about this particular ecu which is prone to failure on the 01-02 sequoia or tundra in internet chatrooms or forums like tundra solutions and edmunds.com,
anybody thought about this,
1981 Toyota Celica GT 486000 mi original engine/tranny with 79 Supra F312 rear
1996 Lexus LS 400 210000 mi and going strong
2002 Toyota Sequoia SR5 4WD 80000 mi too young
Old 10-23-2006, 11:47 PM
bejaar's Avatar
Dealer : Longo Toyota
2002 Toyota Sequoia,
2003 Toyota Camry,
2002 Toyota Tacoma 4x4 Double Cab
Last Online: 09-28-2009 07:09 PM
bejaar is on a distinguished road.
bejaar's Photo Albums
Cool Re: File a complaint to NHSTA regarding VSC/ABS Skid control ECU failure
I think there's a correlation between the TSB caliper/rotor upgrade for 01 and 02 Sequoias and the VSC computer failures that seemed to common for those model years. I wonder if Toyota updated the VSC computer when they did TSB brake upgrade. I did read a long term test drive review on edmunds.com on the Sequoia 2002 model where the VSC lights came on and when taken to the dealer it was attributed to low brake fluid. Perhaps it was it a sign that the VSC computer was about to fail. I do think that VSC computer failure could be a safety issue and NHTSA should investigate this matter.
I do have to thank my dealer and Toyota for stepping up to the plate and repairing my VSC computer for free. I love driving my Sequoia 4x4 offroad and consider it a quality built SUV.
edmunds Sequoia 2002 review: Inside Line: Long-Term Test: 2002 Toyota Sequoia - Wrap-up: January 2004
Old 10-25-2006, 12:34 AM
bejaar's Avatar
2003 Toyota Camry,
Talking Re: File a complaint to NHSTA regarding VSC/ABS Skid control ECU failure
I read my 2002 Sequoia Owner's Manual and read the section on the Vehicle Skid Control System. In bold lettering on page 145 it said the following:
The vehicle skid control system helps provide integrated control of the systems such as anti-lock brake system, traction control, engine control, etc. This system automatically controls the brakes and engine to help prevent the vehicle from skidding when cornering on a slippery road or surface or operating steering wheel abruptly.
The way I read it (I could be wrong) is that the VSC computer is integrated with the Engine Control Computer and should be covered under the Powertrain Warranty which covers the engine control computer.
The Powertrain Warranty is 60 months/60,000 miles.
Any thoughts?
Old 10-25-2006, 08:43 AM
Ray's Avatar
Ray Ray is offline
Dealer : Classic Toyota Scion
2001 Toyota Sequoia
Last Online: 11-17-2009 01:13 PM
Ray is on a distinguished road.
Ray's Photo Albums
Default Re: File a complaint to NHSTA regarding VSC/ABS Skid control ECU failure
I called toyota (not the dealer) twice and talked to different person, regarding the VSC computer is covered under powertrain warranty, and they said it is not covered under the powertrain warranty but covered with bumper to bumper warranty.
Old 10-27-2006, 01:01 AM
el_madmaster's Avatar
Dealer : Burdick Toyota
2001 Toyota Sequoia,
- Other - 1988 Nissan 300ZX
Last Online: 07-26-2009 07:56 PM
el_madmaster is on a distinguished road.
el_madmaster's Photo Albums
When did you have the VSC replaced for free, and was it within the warranty?
1988 Nissan 300zx 5sd 71,000 miles
1995 Nissan Pathfinder 4x4 5spd 90,000 miles (sold, frame gone)
2001 Sequoia Limited 4x4 119,000 miles (some electronic issues, manifolds, otherwise solid and not a single rattle woot)
Old 10-27-2006, 01:09 AM
bejaar's Avatar
2003 Toyota Camry,
It was replaced on Monday. My Sequoia still has the Powertrain warranty but the bumper to bumper is gone. I forgot to get the extended warranty.
Old 10-27-2006, 01:30 PM
bikol-ini's Avatar
2002 Toyota Sequoia
hello, for owners with problematic VSC/ABS/SKID light on the SEQUOIA whivh most is probably out of warranty unless youve got extended warranty, the only way toyota will recognize this problem is to report or file a complaint to NHSTA, read all the complaints that were filled on the sequoia here, this is the website to file a complaint IVOQ - File a Complaint and go from there, and probably you were aware of the duscussion also at edmunds.com, and if i remember there was a thread here that someones vsc caught on fire and it was even caught on video, just that they will conduct an investigation, well its up to you guys who has this problems to act, unless you dont mind paying up big bucks, this might be a chance for a recall and save you some money
Old 11-03-2006, 01:38 PM
bikol-ini's Avatar
2002 Toyota Sequoia
hello, to lakeside, hows your 04 sequoia after the fire of the vsc, did you file a report to NHSTA, about the incident? people with problems should file a report/complaint so that they will investigate it, maybe there is really a fluke on the design of the vsc.abs system and all it needs is updating it
Old 11-08-2006, 10:16 AM
rivan's Avatar
Employee of the Month
Dealer : Seeger Toyota
2002 Toyota Sequoia
Last Online: 06-10-2009 10:06 AM
rivan is on a distinguished road.
rivan's Photo Albums
Complaint filed:
Your Confirmation number (ODI Number) is: 10172909
'02 Sequoia Limited
Old 11-09-2006, 09:36 AM
Dealer : Vernon Toyota
2003 Toyota Sequoia
Last Online: 11-26-2007 09:48 PM
thanna is on a distinguished road.
thanna's Photo Albums
I have a '03 Sequoia that is now off factory warranty. My VSC Light came on as per many of the reports you find posted. After taking it to the dealer they found 2 codes coming up specific to the problem and advised that both the Skid Control Computer and the Enigine Control Computer (ECC) required replacing. Looking around on tundrasolutions.com I found the Technical Service Bulletins specific to this issue (thanks guys for these postings). I then contacted Toyota customer service and complained about the issue and they negotiated with the local Toyota dealer and came back with an offer of each party covering one third the repair bill. The work is now complete and problem is resolved. Thanks again to everyone here for there posts - saved my about $1500.00 by having proof of the problem and being able to properly state my case.
Old 11-09-2006, 02:59 PM
Dealer : Acton Toyota of Littleton
2006 Toyota 4Runner
Last Online: 10-19-2009 11:19 AM
cheepyankee is on a distinguished road.
cheepyankee's Photo Albums
what years are likely to have vsc/abs skid control issues. Getting an 04, how can I tell it has the issue?
Old 11-18-2006, 12:53 PM
bikol-ini's Avatar
2002 Toyota Sequoia
this issue seems to be frequent on 01-02 and early 03 sequoias,
Old 11-26-2006, 02:27 AM
nem's Avatar
nem nem is offline
Dealer : Penticton Toyota
2002 Toyota Sequoia
Last Online: Yesterday 01:42 AM
nem is on a distinguished road.
nem's Photo Albums
It seems the brake TSB is only 01-02's but the VSC/TRAC failure is on all years (at least beyond 03). I just had the brake TSB done - my brakes work far better than before, stops better and pedal feel is better. The truck started hesitating right after the work was done, I took it back to the dealer and (because of this website - THANKS) told them the mechanic must not have positioned the sensors in the wheels correctly and the zero point calibration would not have worked. He told me the systems are not tied together and it must be my throttle positiong sensor, turns out I was right everything seems good now - knock on wood. - The two systems are definately tied together and I would (and will if it fails) put up a huge stink over getting it covered under powertrain warranty.
I have to wonder if any people have paid to replace their VSC computer after the brake TSB was done needlessly due to mispositioned wheel sensors.
Old 12-11-2006, 06:49 PM
bikol-ini's Avatar
2002 Toyota Sequoia
bump, thanks
Old 12-12-2006, 10:59 AM
bikol-ini's Avatar
2002 Toyota Sequoia
the irony is that a lot are complaining or having problems with VSC/ABS Skid control yet few people are doing something about it like filing a complaint with NHSTA, case by case basis toyota/dealer will do a replacement but not always the case youve got to pony up at least 1500 bucks,minimum, anyways good luck, to all those with problems
Dynamic Laser Cruise Control TS Support Toyota, Scion & Lexus News 0 09-20-2006 09:07 PM
Lexus Technology Roundup 2007 TS Support Toyota, Scion & Lexus News 0 09-12-2006 08:53 AM
How, EXACTLY, does the ECU work? gnlw Engine & Drivetrain 7 12-24-2005 12:17 AM
Tundra ECU Upgrades - THIS is what we need... Mudog715 Engine & Drivetrain 12 07-31-2003 07:53 PM
