2006 tire inflation light stays on
+ Reply to Thread
Results 1 to 5 of 5
Thread: 2006 tire inflation light stays on
  1. #1
    Supporter wyun has disabled reputation
    Join Date
    Mar 2006
    Location
    Corona
    Posts
    11
    Liked
    0 times
    Rep Power
    0
    Exclamation 2006 tire inflation light stays on
    2006 limited sequoia - my tire inflation light stays on. Have reset the tire inflation setting. Have taken car to tire shop and all 4 tire pressure were normal within specs of psi. Dont know what else to do. have about 37000 mile on car.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter Johnnny Rock is on a distinguished road. Johnnny Rock's Avatar
    Join Date
    Feb 2002
    Location
    New Jersey
    Posts
    695
    Liked
    0 times
    Images
    1
    Rep Power
    12
    Default Re: 2006 tire inflation light stays on
    Quote Originally Posted by wyun View Post
    You didn't check the 5th tire!! LOL Everyone makes this mistake...It's the spare tire that is low on air. Top off the spare and the light WILL go out! Johnnnny
    2004 Ford Lightning (Sonic Blue)
    2003 Cobra with LOTS of work : ) (BLACK)
    1996 Cobra (White)
    1999 Tacoma 4 wheel drive (Purple in Color)
    2002 Tundra Limited (Dark Green or Jade In Color)
    2002 Chevy Corvette Z06 (Candy Apple Red)
    2003 HighLander Limited (Silver In Color)
    2005 Sequoia Limited (Phantom Grey)
  4. #3
    Rookie tmcharris is on a distinguished road.
    Join Date
    Jan 2005
    Location
    Richmond, VA
    Posts
    3
    Liked
    0 times
    Rep Power
    0
    Unhappy Re: 2006 tire inflation light stays on
    Did you check your spare tire, as well? They utilize all five tires for pressure and rotation scheme. Good luck!
    2005 Sequoia Ltd 4x4
    DVD Nav, Rear DVD
  5. #4
    Junior Member roblafd1 is on a distinguished road. roblafd1's Avatar
    Join Date
    May 2004
    Location
    Alta Loma, CA
    Posts
    55
    Liked
    0 times
    Rep Power
    10
    The tire pressure sensors do not have a preset pressure range, they only respond to a pressure change from the pressure they were at when the system was reset.
    The proper way is to properly inflate your tires to the proper pressure (don't forget the spare!), THEN reset the system as described in the owners manual. If you reset the system (using the button) when any tire is low or high on pressure, you are telling the system that the current pressures are right. The light will go on when there is a substantial change in tire pressure (some say a rise in temp. will also set off the light) So if a tire is low when you reset the system , it will be dangerously low before a light comes on.
    2005 SR5 Dbl Cab, Silver Sky Metalic, Camburgs, 285 Nittos, Truxedo Lo-Pro, Line-X, HD Headlight wiring, 90\100w Phillips Rallys, GT seat covers, Fog light mod, Loud a$$ air horn, Debadged (visors too), VSE subwoofer, Rear sway bar, tailgate lock, led's, prodigy controller, Scan Gauge II, NO muffler..........
  6. #5
    Join Date
    Feb 2002
    Location
    New Jersey
    Posts
    695
    Liked
    0 times
    Images
    1
    Rep Power
    12
    Quote Originally Posted by roblafd1 View Post
    I was told that ALL the tires have to be within five six or seven pounds of each other in order to be set. So, if all five tires are at 40psi and you hit the set button it will be set. If any one of the five tires change pressure either higher or lower by five six or seven pounds the light will go on. (I forgot what the exact number is for the light to go on, I think it is one of the three...either five six or seven, not sure witch one) If you try to push the set button when one of the five tires is off by either five six or seven the system WILL NOT set. If you have five tires with lets say 40psi in 3 of them and 42psi in the other 2 and you try to set the system it will set as long there is not more then either five six or seven pounds difference in the five tires. Johnnny
    1996 Cobra (White)
  1. Tire Pressure Warning Light
    By peak7tiger in forum Corolla / Matrix
    Last Post: 02-05-2007, 01:26 PM
  2. Spare tire stolen from my 2006 4Runner
    By IU_gal in forum 4Runner
    Last Post: 09-20-2006, 10:05 AM
  3. Fog Light Mod Quirks
    By nhparrot in forum Electrical & Computer Systems
    Last Post: 03-28-2002, 10:16 AM
Posting Permissions
  • You may not post replies
  • You may not edit your posts
