Re: 01 Sequoia Antenna Replacement
This is what I used when I needed to replace/fix mine.
(I searched the Audio/ Electrical section)
But these directions should help.
Take the top nut off the antenna then have someone turn on the radio. The entire mast should just start coming out like a snake.
That top nut on the fender actually keeps the antenna in place. After you get the entire antenna mast out, compare it to the new one to make all the parts came with it. Remember which way the teeth were facing when the old one came out as you will need to do the same. With the radio still on, feed the plastic cable into the tube. When it stops, have someone turn off the radio because you will have to guide the new mast into place. It may take a few times but it's pretty easy. If the antenna is not all the way down on the first try, turn the radio back on and redo the process. After it is all the way down, reinstall the top nut on the fender and you will have a new mast installed
2001 Sequoia 2WD SR5
Mods:20s wrapped w/ 295/45/20
Borla Dual Side Exit Cat Back Exhaust
JBA Headers
OEM Foglights Install
TRD Drop-In Filter
