2003 Alarm System w/ Engine Immobilizer
+ Reply to Thread
Results 1 to 3 of 3
Thread: 2003 Alarm System w/ Engine Immobilizer
  1. #1
    Lurking Member grice is on a distinguished road.
    Join Date
    Aug 2002
    Location
    Colorado Springs, CO
    Age
    48
    Posts
    46
    Liked
    0 times
    Rep Power
    11
    Default 2003 Alarm System w/ Engine Immobilizer
    The standard equipment list for the 2003 Sequoia Limited states something about an Alarm System with Engine Immobilizer.
    Can anyone describe what kind of alarm this is?
    Thanks.
    Gerald
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Rookie SoFlaJB is on a distinguished road. SoFlaJB's Avatar
    Join Date
    Oct 2002
    Location
    Ft. Lauderdale, FL
    Posts
    13
    Liked
    0 times
    Rep Power
    0
    Post
    Here is what you get with the 2003 Limited:
    - Vehicile Intrusion Protection (VIP): If someone attempts to break in (unlock the door without a key, open the hood, disconnect/reconnect the battery terminal, etc...) the horn sounds and lights begin to flash. There is an optional glass breakage sensor that complements the system (not standard on any SQ).
    - Engine Immobilizer: A unique code is stored in both the key and the ignition switch. When you put the key in, the codes are compared and a match disables the security lock. If the key fits but the codes do not match, the immobilizer prevents engine start.
    SoFlaJB
  4. #3
    Join Date
    Aug 2002
    Location
    Age
    48
    Posts
    46
    Liked
    0 times
    Rep Power
    11
    Thread Starter
    Smile Perfect
    SoFlaJB:
    Thanks for the info!
    Gerald
Posting Permissions
  • You may not post replies
  • You may not edit your posts
