2002 Sequoia Antenna Replacement
+ Reply to Thread
Results 1 to 8 of 8
Thread: 2002 Sequoia Antenna Replacement
  1. #1
    Supporter MMAADD357's Avatar
    Join Date
    Apr 2006
    Location
    SEQUOIA LAND, USA
    Posts
    26
    Liked
    0 times
    Rep Power
    9
    Default 2002 Sequoia Antenna Replacement
    Well, after telling her TIME AND TIME again not to do it...my wife took the truck to the car wash and didn't lower the antenna.
    As you can imagine, I now have 1/2 an antenna. ANY feedback that can be given would be very much appreciated!
    I saw this on a website and was wondering if it could replace a power antenna, or if anyone knows of another solution. I saw power replacements on Ebay for from $39 - $89, but I would love to replace with a stubby.
    Stubbie Replacement Antenna=
    Thanks in advance...
    Michael
    The true test of a person’s character is not how they react when things are going well; it is how he or she performs when faced with adversity.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member pastorbrad's Avatar
    Join Date
    Feb 2004
    Location
    Dover, MA
    Age
    66
    Posts
    279
    Liked
    1 times
    Rep Power
    12
    Default Re: 2002 Sequoia Antenna Replacement
    Well you worst case is dealer parts and labor to replace the power antenna. Close to 400. I thought about using a stubby or nonpower but figured on trade or private sale the buyer would expect original equipment.
  4. #3
    Junior Member dcab03's Avatar
    Join Date
    Nov 2004
    Location
    New Orleans, LA
    Age
    37
    Posts
    189
    Liked
    0 times
    Rep Power
    11
    You probably only have to replace the mast itself to keep the power antenna working for like $50 or so (not sure about the price it has been a while since I bought a mast) Or you could probably just get the antenna base for a tundra and buy the stubbie fixed antenna. The DC tundra base should be the same and do a little work with the antenna cable and you are good to go. I cannot confirm about the Tundra (but the front fenders should be the same) because I have a Seq with the antenna in the glass and a Tacoma.
    1998 Chevy Tahoe
    2008 Saturn VUE
    1993 Acura Integra
  5. #4
    Junior Member mcmatt's Avatar
    Join Date
    Feb 2002
    Location
    Austin, TX
    Age
    48
    Posts
    189
    Liked
    2 times
    Rep Power
    404
    You can get a mast only replacement from EBay for about $25. They are very easy to install.
    Try antennamastsrus.com
    Also, I saw some generic masts in Pep Boys for Toyota, Nissan, and GM. They were only about $20 and they may work fine.
    You can replace by unscrewing a retaining nut and turning the radio on. the antenna will be pushed out. You insert the new plastic belt of the replacement and turn the radio off. It will pull the new one in.
    Good Luck
  6. #5
    Join Date
    Nov 2004
    Location
    New Orleans, LA
    Age
    37
    Posts
    189
    Liked
    0 times
    Rep Power
    11
    If you are lucky it is that easy. I say about 90% of the masts I have changed on various car models about a 1-2 in peice of the old mast is broken off in the motor which means you have to take the motor out and take it apart to get the broken piece out. It is not a hard job but just time consuming.
    1998 Chevy Tahoe
    2008 Saturn VUE
    1993 Acura Integra
  7. #6
    Join Date
    Apr 2006
    Location
    SEQUOIA LAND, USA
    Posts
    26
    Liked
    0 times
    Rep Power
    9
    Thread Starter
    Thanks to you all for your input. I will let you know how it goes.
    Michael
  8. #7
    Join Date
    Feb 2002
    Location
    Columbus, OH
    Age
    70
    Posts
    122
    Liked
    0 times
    Rep Power
    14
    Exactly where is this "nut" that I need to remove to change just the mast??
    Winter has been hard on my mast and it is now sticking like crazy and I need a whole, complete antenna to hear certain stations.. OR is there a lubricant or cleaner that one can use to get it back working? (here I am a lube engineer asking about a lube: but, been there done that, using a lube where it should be dry and paid the price)
    George Morrison
  9. #8
    Join Date
    Feb 2002
    Location
    Austin, TX
    Age
    48
    Posts
    189
    Liked
    2 times
    Rep Power
    404
    It is at the base of the antenna. It is probably chrome. You will have to have a spanner wrench or carefully use slot screwdrivers to "tap" it loose.
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
  1. 99 4runner antenna replacement, HOW?
    By Begal in forum 4Runner
    Last Post: 07-08-2009, 09:19 AM
  2. Replacement battery for Sequoia 2001
    By jbaugh in forum 1Gen-Sequoia
    Last Post: 03-18-2009, 06:14 AM
  3. Replies: 8
    Last Post: 01-20-2007, 01:02 AM
  4. 2002 Sequoia Transmission fluid and filter
    By btp in forum 1Gen-Sequoia
    Last Post: 10-10-2006, 12:24 PM
  5. Swapping 2002 Sequoia Rear Axle
    By lawnmowing20837 in forum 1Gen-Tundra
    Last Post: 01-14-2006, 10:15 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
