Sand Bags For Winter Driving
+ Reply to Thread
Results 1 to 9 of 9
Thread: Sand Bags For Winter Driving
  1. #1
    Join Date
    Apr 2004
    Location
    Cheyenne, WY
    Posts
    13
    Liked
    0 times
    Rep Power
    0
    Default Sand Bags For Winter Driving
    This is my first winter with the Tundra. Has anyone had experience putting sand bags in the back? Does it make a difference? How much weight should I use?
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Junior Member wes 03's Avatar
    Join Date
    Mar 2003
    Location
    TEXAS TECH UNIVERSITY, LUBBOCK, TEXAS
    Age
    30
    Posts
    464
    Liked
    0 times
    Rep Power
    13
    i usually pick up 6 big rig wheels, they weigh quite a bit. it helps quite a bit, just make sure you have good tires, i love my bfg all terrains in the snow. just drive slow
    wes
  4. #3
    Veteran Member anmrivera's Avatar
    Join Date
    Aug 2002
    Location
    United Kingdom
    Age
    40
    Posts
    565
    Liked
    0 times
    Rep Power
    17
    Quote Originally Posted by cedarwinds2003
    Sorry can't help you. If you have a LSD you probably will not need em. I live in the hilly part of Nebraska and have no problem starting on hills with my LSD. Good luck.
    2003 Tundra 4x4 Access cab V-8, SR5, Silver Sky Metallic, TRD Off-Road package, Tow package, LSD, cold weather prep. package, Running boards, Convienence Package, Line-X bedliner, debadged, 4 window visors, Blue Cyber Eyes, $5 rs3200 upgrade , Fog light mod.
    2005 Sienna LE 8 PAX, White, Full Curtain airbags, Tow prep package, VSC, Rear Disk brakes, rear audio, aftermarket entertainment center(will be bought soon)
    I'm a proud Toyota Bigot!!!
    Midwesterners checkout the midwest forum!Click here
  5. #4
    Supporter MustangSally's Avatar
    Join Date
    May 2001
    Location
    Over Yonder
    Posts
    961
    Liked
    5 times
    Rep Power
    2284
    I carry two 5-gallon plastic buckets full of sand if I'll be driving on snow or ice. I secured the lids with duct tape and put the buckets over the rear axle on each side. I also carry tire chains and a shovel, but have not had to use them yet.
    ~MS
    ~~MustangSally~~
    2001 Tundra Limited TRD 4x4
    Imperial Jade Mica/Thunder Gray Metallic
  6. #5
    Assistant Administrator nhparrot's Avatar
    Join Date
    Sep 2000
    Location
    New Hampshire
    Age
    62
    Posts
    6,434
    Liked
    24 times
    Rep Power
    1674
    During the winter I load the bed with 6 sand-tubes over the axle.
    ~Glenn
    Yes I am a pirate!
    "To err is human. To arrr is pirate."
  7. #6
    Supporter keithfoo's Avatar
    Join Date
    May 2002
    Location
    USA
    Posts
    33
    Liked
    0 times
    Rep Power
    14
    If you use sand bags, try to place them on a piece of plywood. This way they will freeze to the wood and will be easier to remove if needed. I use to fill 2, 50lb grain bags half way with sand and place them over the axel on my F150 and on my 2wd Tundra. I avoided situations where I could get stuck and for the most part I never got into a bad situation on snow and or ice.
  8. #7
    Join Date
    Aug 2002
    Location
    Niagara Falls, NY
    Posts
    279
    Liked
    0 times
    Images
    2
    Rep Power
    17
    The really important issue here is not to create a potential deadly projectile in the event of a quick stop (as in accident). There is only one thin layer of metal / glass between you and the great outdoors!
    Sand sealed to stay dry (will fly apart on impact w/ the truck cab) if the worst happens, safer for you and passengers.
    I've not needed any extra weight at all in my 03 4x4 - quite a surprise actually.
    Dedicated winter tires are a real eye opener in terms of added safety and performance.
    P
  9. #8
    Join Date
    Jul 2003
    Location
    Southeast
    Posts
    860
    Liked
    0 times
    Rep Power
    13
    I had 5 sandbags at 70lbs each
  10. #9
    Junior Member TruckGuy's Avatar
    Join Date
    Aug 2004
    Location
    Los Angeles
    Posts
    180
    Liked
    0 times
    Rep Power
    12
    starting with my last truck, and now with my Tundra. I like keeping around 100, or so lbs in the bed year round...rides better!
    if it ever snows here in LA....im ready!!!
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
  1. Best oil to run in the 4.7 Tundra?
    By SMOKEATR in forum Engine, Intake, Exhaust, Induction
    Last Post: 03-22-2007, 03:33 PM
  2. driving lights w/parking lights
    By francirb in forum Electrical & Computer Systems
    Last Post: 12-17-2003, 05:34 AM
  3. Hella 500 driving lights
    By jinx in forum Electrical & Computer Systems
    Last Post: 05-11-2003, 04:34 AM
  4. Ever get a foot cramp while driving?
    By TampaBayTundra in forum Off-Topic
    Last Post: 04-01-2003, 07:52 AM
  5. driving lights wiring suggestions
    By nhparrot in forum Electrical & Computer Systems
    Last Post: 03-28-2002, 10:14 AM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
