Re: steering slop
It's probably your upper steering shaft. Collapsible joint is loose. Get under the dash and hold onto the coupler while you trun the wheel and see if you feel the slop there. I've seen numerous trucks (including mine) with the same problem. Shafts are expensive also, but easy to change.
