Go Back   Tundra Solutions Forum > Truck Forums > 1Gen-Tacoma
Old 08-01-2007, 08:17 AM
Dealer : Boch Toyota
1998 Toyota Tacoma
Last Online: 05-04-2008 09:05 AM
TeddyD is on a distinguished road.
TeddyD's Photo Albums
Angry '98 Tacoma A/C not working
I have a 1998 Tacoma 4x4 regular cab with the 4cyl engine. My A/C doesn't work. I have noticed that when I press the A/C button on the dash, the clutch attached to the compressor doesn't engage. I checked the voltage to the clutch and it is dead, with the A/C switch in both positions. Thinking that the problem might have been a bad A/C switch, I made the mistake of buying a new one (to the tune of $50), installed it and found that the problem still persists. I checked the fuse in the fuse compartment under the hood and it's ok. I also applied 12VDC directly to the clutch ant it actuates just fine. I'm thinking that there's something simple that I'm not aware of. Any ideas? Thank you.
Old 08-01-2007, 09:54 AM
The Phoenix's Avatar
Moderator
Last Online: 11-06-2009 02:51 PM
Images: 2
The Phoenix's Photo Albums
Default Re: '98 Tacoma A/C not working
Sounds like a relay may be bad, or a wire is obviously bad at some point from the switch to the clutch.
Old 08-01-2007, 12:31 PM
Dealer : Desert Toyota Scion Of Tucson
2005 Toyota Corolla,
2002 Toyota Tacoma
Last Online: 06-07-2009 09:31 AM
Txstick is on a distinguished road.
Txstick's Photo Albums
If it is too low on Freon there is a pressure switch which will not let the compressor engage.
Old 08-01-2007, 04:36 PM
1998 Toyota Tacoma
Question Re: '98 Tacoma A/C not working
Thanks. That sounds like reasonable. I was not aware that there was a pressure switch. I'm assuming that the switch is on the low pressure side. Do you think that enough pressure will be generated by attaching a can of refrigerant to the low pressure side?
Old 08-01-2007, 10:56 PM
ddnail's Avatar
Dealer : Toyota of Muskogee
2003 Toyota Tacoma
Last Online: 06-27-2009 02:30 PM
ddnail is on a distinguished road.
ddnail's Photo Albums My eBay
It might kick on when you hook up the can, but more than likely you'll have to put more than one can in to make the switch bypass.
Someone jump in here if im wrong, but I think the full capacity of that compressor is like 3 cans. Half of one can replaced by compressor oil. In the front of the radiator on the drivers side behind the grill, there is the dryer with a clear glass eye on the top, continue to add freon untill the bubbles in the sight glass go away. That is an old school way of monitering the level of charge in the system. Be carefull here, dont over charge the system or you could damage it or yourself!
Did you have problems with it before it quit working? Or was it just all at once? Sounds like you got a leak to me if there were enough refrigerant (and oil) gone to enable the pressure switch to activate.
AKA..dingdong
Silver 03 Taco Limited TRD 4dr. 4X4 V6 Auto
Extang Tonneau, LineX Liner, 3" Toytec lift with front diff drop, rear Alcan, AAL's w/ degree shims, Procomp shocks front and rear, Locker mod, 285/75/16 Nitto's, Code alarm/remote start CA670, Putco Stainless Grill, Several CUSTOM off road pin stripes
Old 08-02-2007, 08:40 AM
1998 Toyota Tacoma
Thumbs up Re: '98 Tacoma A/C not working
Well, you were absolutely right! I connected the refrigerant hose to the LP service fitting. The pressure there was low (about 18#). As soon as I began to add refriferant, the compressor kicked in and the problem was solved. Thanks for all of your help!!!
Old 08-02-2007, 09:17 AM
2002 Toyota Tacoma
Good deal! You might want to monitor it and if you loose it again you will have to find the leak.
chuck
Old 04-26-2009, 02:50 PM
Dealer : Tarbox Toyota
2001 Toyota Tacoma
Last Online: Today 08:33 AM
kingston73 is on a distinguished road.
kingston73's Photo Albums
I know this is an old post, but have you had problems since your fix? I just posted a thread about this same thing, and then I found your question.
2003 Corolla A/C not working shg1 Corolla Matrix 4 06-24-2007 01:25 AM
05-07 tacoma front suspension limits chain use barmour Tacoma 4 05-03-2007 03:26 PM
Advice...06 and older Tundra...or Tacoma? MGH-PA 1Gen-Tundra 14 02-27-2007 12:37 PM
Decisions...weigh in on Tundra and Tacoma. MGH-PA Tacoma 18 02-18-2007 11:56 PM
New Tundra too big? Buy a Tacoma? Hickleberry Tundra 33 02-12-2007 11:38 AM
