4wd on dry road
+ Reply to Thread
Page 1 of 2 12 LastLast
Results 1 to 15 of 17
Thread: 4wd on dry road
  1. #1
    Join Date
    Aug 2007
    Location
    upstate
    Posts
    4
    Liked
    0 times
    Rep Power
    0
    Default 4wd on dry road
    hello-
    i just purchased a 1999 Tacoma SR5 this weekend. the seller was very touchy about testing out the 4wd. he says you should never, ever use 4wd on a dry road. he took me on a patch of grass and demonstarted Hi 4wd for about 10 seconds. it seemed to work great. he put it in Low 4wd and drove about 5 feet. --so at least i know it works.
    but is this true? --is it really bad to use 4wd on a dry road? is he exaggerating?
    thanks.
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter The Phoenix's Avatar
    Join Date
    Oct 2006
    Location
    TundraSolutions.com
    Posts
    2,495
    Liked
    4 times
    Images
    2
    Rep Power
    142
    Default Re: 4wd on dry road
    Welcome to TS dan-o!
    The salesman is correct that you should not drive the truck on dry pavement in 4WD. It will put additional stress on the drivetrain. I am guilty of using 4x4 on wet pavement/concrete once before and there are no signs of damage though.
    They say you are supposed to use your 4WD at least once a month too.
  4. #3
    Join Date
    Aug 2007
    Location
    upstate
    Posts
    4
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    thanks for the welcome, and the answers.
    can you tell me what you mean by 'binding'?
    does turning stress the drivetrain even off-road?
    what about using 4wd on an icy road?
    danny
  5. #4
    Join Date
    Oct 2006
    Location
    TundraSolutions.com
    Posts
    2,495
    Liked
    4 times
    Images
    2
    Rep Power
    142
    Quote Originally Posted by dan-o View Post
    danny
    Binding is that extra stress on the drivetrain. All 4 wheels are turning at the same speed and need as little resistance as possible. This is why pavement is bad for 4wd because there is alot of resistance. When off-road, the tires have less resistance because of the softer terrain (usually dirt or mud) I've used 4wd on an icy road before, but again the tires don't have as much resistance, so it's ok. Just watch out for the patch of road that isn't icy though.
  6. #5
    Join Date
    Jun 2004
    Location
    Middle GA
    Age
    36
    Posts
    374
    Liked
    0 times
    Images
    10
    Rep Power
    18
    In 4WD, the transfer case has locked the speed of the front wheels to the speed of the rear wheels. When you turn, the front wheels and rear wheels try to rotate at different speeds--this is what causes binding. You can turn in 4WD when the wheels will be able to slip to make up for the difference in speed. Ice especially, gravel, sand, loose dirt, and very wet roads are fine. The more traction you have, the better the chance of binding--but the better traction you have, the less you need 4WD.
    On some other vehicles, you can engage 4WD but they have an unlocked center differential that allows the front and rear wheels to turn at different rates. That's usually the characteristic of a full-time 4WD.
  7. #6
    Join Date
    Jul 2007
    Location
    Trafalgar,In
    Posts
    13
    Liked
    2 times
    Rep Power
    0
    I guess I don't understand the difference between fulltime and partime 4 wheel drive.Back in the early 80s I had a '78 GMC with fulltime 4wd and you could drive it on any surface.
  8. #7
    Join Date
    Jun 2004
    Location
    Middle GA
    Age
    36
    Posts
    374
    Liked
    0 times
    Images
    10
    Rep Power
    18
    Quote Originally Posted by boxcar View Post
    Full-time 4WD (also marketed as AWD) means you had open differentials all around. The wheels could all turn at different speeds. Power would only go to the wheel with the least traction.
    Part-time 4WD means at least the center differential is locked, making the average speed of the front wheels turn at the same average speed of the rear wheels. Power would go to the front wheel with the least traction AND to the rear wheel with the least traction (50/50 split).
    Wikipedia: Differential (mechanical device)
    Full-time 4WD with a lockable center diff is probably the most useful, ala Sequoia. I think they call it Multi-mode on there.
  9. #8
    Join Date
    Jul 2007
    Location
    Trafalgar,In
    Posts
    13
    Liked
    2 times
    Rep Power
    0
    Thanks for the good information!!
  10. #9
    Join Date
    Aug 2007
    Location
    upstate
    Posts
    4
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    ditto that..... Thanks!
    is binding that 'shaking' that happens when you make a sharp turn in 4wd? --is it something you notice, or does it just sort of happen and it's no good....
    thx again
  11. #10
    Join Date
    Jun 2004
    Location
    Middle GA
    Age
    36
    Posts
    374
    Liked
    0 times
    Images
    10
    Rep Power
    18
    The shaking you felt is probably from the wheels forcefully slipping to release the tension created by binding. If you're at that point, you're stressing your drivetrain.
    Binding is really the conflicting forces you're putting on your drivetrain--something has to give way--either tires slipping, or the drivetrain flexing, bending, and breaking. The driveshafts have a "little" play in them that probably flexes a bit and is probably why more people haven't destroyed their transmissions.
    Minor binding like that will probably lead to more play over time. My guess is that over time with minor binding, you're more likely to feel rough starts from a stop (drivetrain clunking) than you are to actually break something.
  12. #11
    Leader of Group Evil DevinSixtySeven's Avatar
    Join Date
    Oct 2001
    Location
    Snowy Highlands
    Posts
    11,128
    Liked
    728 times
    Images
    22
    Rep Power
    12366
    The 4WD system is actually fairly robust, at least on stock tires. The tires will lose traction, in general, before something breaks.
    I would love to have a center differential in my Tundra but I'm not sure the Seq center diff would hold up to the stress of larger tires, lockers and such.
    Don't use your 4WD on the pavement, even in straight lines, especially on the highway. It's bad for the system, it's also very bad for your tires. Find a dirt road...or wait til it rains really hard and make a slow loop around the block while it's raining, disengaging the 4WD for the turns.
    If you got 4WD because it snows in your area but have no use for the system otherwise, I highly recommend getting manual locking hubs from Offroad Solutions. You'll be able to open the hubs and engage the transfer case on the pavement, so it stays lubricated but doesn't hurt the system or your tires.
    The ADD system uses car-style semi-float hubs, so the front diff is always being lubricated. It's the ADD system and the transfer case that need exercise.
    -Sean
    GFX by FreedomEagle50
    1-Gen Tundra Offroad Technical FAQ Index
    Manual Hubs
    OB's cup size: 36DD
    "some people will call you stupid but its worth a try because i know i also want one more inch."--SouthernTundraSC
  13. #12
    Join Date
    Aug 2007
    Location
    upstate
    Posts
    4
    Liked
    0 times
    Rep Power
    0
    Thread Starter
    thanks again all.
    well luckily i haven't felt any shaking in my tacoma!
    but i do remember that shaking from when i owned an 87 landcruiser. (as well as the manual locking hubs!)
    i will be doing a good amount off-road driving so i guess i'll leave the 4wd for now.
    thanks again for all the great info.
    danny
  14. #13
    Join Date
    Jul 2004
    Location
    Atlanta, GA
    Posts
    94
    Liked
    0 times
    Rep Power
    11
    let me get this straight, if u r offroading, u can NOT leave it in 4wd when taking turns? so do u pop it back & forth between 2wd & 4wd while driving? what about uneven terrain?
  15. #14
    Join Date
    Oct 2001
    Location
    Snowy Highlands
    Posts
    11,128
    Liked
    728 times
    Images
    22
    Rep Power
    12366
    if u r o/r, u can b in 4wd 4 the wHoLe tIMe even if u r driving sLiCkRoCk. if u 4get & u r in 4wd on bitumen u may b 4lorn since ur tires wear 2 fast. ur tires h8 2 slip if traction good, but n o/r situ8tions & crawling they will b fine, drivetrain sTrOnG lIkE oX even if driver sMaRt LiKe tRaCtOr. no need 2 shift out but if u have convert wit teh manual hubs u will have the easy time when on teh slickrock.
    I hope that helped.
    -Sean
    Manual Hubs
    OB's cup size: 36DD
  16. #15
    Join Date
    Jul 2004
    Location
    Atlanta, GA
    Posts
    94
    Liked
    0 times
    Rep Power
    11
    no because it didn't make any sense, speak english!
    Quote Originally Posted by DevinSixtySeven View Post
    I hope that helped.
    -Sean
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
  1. 4Runner multimode 4wd system
    By FreeRideKipp in forum 4Runner
    Last Post: 02-23-2011, 08:05 AM
  2. Replies: 9
    Last Post: 10-24-2006, 03:04 PM
  3. Flashing 4WD indicator
    By dephelps in forum T-Case, Driveshaft, Diff, Axle, Hub
    Last Post: 02-11-2006, 02:15 PM
  4. 97 4Runner Limited 4WD engaging problem
    By 4RUNN!N in forum Out-of-Production Toyota Trucks
    Last Post: 11-29-2005, 12:45 PM
  5. TRD Off Road, Off Road & More. (LSD)
    By TundraTRX in forum T-Case, Driveshaft, Diff, Axle, Hub
    Last Post: 02-09-2005, 08:42 PM
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
