How do I cut off "ONLY" the fuel pump on a 2001 Tacoma SR5 (3400 engine)??
I bought an injector cleaning kit and I need to cut off ONLY the fuel pump and not the injectors to run this kit. Apparently when I pull the relay or the 20A fuse marked "EFI", it cuts off the fuel pump, but it also seems to cut off the injectors...
I traced the fuel lines to the filter and it goes into the tank so I presume the fuel pump is in the fuel tank??
Anyone can provide an access point or a way to disconnect just the fuel pump without having to pull the EFI relay or EFI 20A fuse??
Re: How do I cut off "ONLY" the fuel pump on a 2001 Tacoma SR5 (3400 engine)??
Hey man, I don't mean to hijack your thread but I've been looking for an injector cleaner also and have had a hard time finding one that's not an arm and a leg! Can you tell me what kind you got and where?
Thank's for any info.
AKA..dingdong
Silver 03 Taco Limited TRD 4dr. 4X4 V6 Auto
Extang Tonneau, LineX Liner, 3" Toytec lift with front diff drop, rear Alcan, AAL's w/ degree shims, Procomp shocks front and rear, Locker mod, 285/75/16 Nitto's, Code alarm/remote start CA670, Putco Stainless Grill, Several CUSTOM off road pin stripes
No prob. PM for the details.
As far as shutting of fuel only, I answered my own question. I looked hard enough and there is a connector on the top of the fuel tank I used to disconnect the pump. That's the only way (on my model anyway) you can run the kit.
Thank's Lyle, just purchased the kit today plus the master adapter kit (I got a lot of cars that need cleaning) from ebay. I really appreciate the info
AKA..dingdong
Originally Posted by gtyler2
pull the fuel pump relay in the box under the dash on the drivers side.
Well almost right, that will not only cut off the fuel pump, but also the injectors as well. Depending on what your working on,(like cleaning the injectors) the only way to disable the fuel pump alone and not the injectors is to disconnect the fuel pump at the wireing harness on top of the fuel tank. It's a b!tch to get to, but it's the only way.
AKA..dingdong
