Old 09-27-2007, 11:24 AM
Dealer : Fremont Toyota Scion
2004 Toyota Tacoma
Last Online: 08-03-2008 01:11 PM
omeganman may have some regrets.
omeganman's Photo Albums
Default Weird electrical issue...
I have an issue with my door power ammenities. All at one time, both power windows and my driver side power lock stopped working. I can still lock and unlock doors with my key-remote and with the lock button on the passenger side.
I have been going through the trouble shooting guide in the shop manual, the first thing was check fuses, whcih I did and all are good. The next thing is the ignition switch. This would make sense to me if it was just the windows, becuase both sides are affected. But how could the passenger lock still work, and the all of the locks still work with the remote?
Should I still check/ replace igniton switch? Or do the symptoms suggest something else. What is the part number for the switch?
Old 09-27-2007, 06:06 PM
ray_gallup's Avatar
Dealer : John Weiss Toyota City
1997 Toyota RAV4,
2004 Toyota Tacoma
Last Online: 07-18-2009 01:26 PM
ray_gallup may have some regrets.
ray_gallup's Photo Albums
Default Re: Wierd electrical issue...
I had a simular problem with my supra it was the switch that was bad
Old 09-27-2007, 06:35 PM
Dealer : First Team Toyota
2004 Toyota Tacoma
Last Online: 07-06-2008 01:37 PM
sizzler may have some regrets.
sizzler's Photo Albums
Default Re: Weird electrical issue...
Were you in the drivers door recently?
Check your connection within the drivers door.
I installed my door speakers and 2-3 months later my power windows/locks stopped working, while my remote still works.
Even if you were'nt in the door, It might have come loose.
Red 04 Tacoma TRD SR5 4dr. 4wd.
Onboard Air
4 locomotive air horns
Alarm Mod
Re-programmed door locks
RR-Diff lock mod
Nasty stock bed-liner
Sound system from HELL!!!
Old 09-27-2007, 07:01 PM
Hi Volt's Avatar
Dealer : Sunrise Toyota - Abbotsford
Last Online: 03-04-2010 12:39 AM
Images: 7
Hi Volt will become famous soon enough. Hi Volt will become famous soon enough. Hi Volt will become famous soon enough. Hi Volt will become famous soon enough. Hi Volt will become famous soon enough. Hi Volt will become famous soon enough.
Hi Volt's Photo Albums
The driver's side switch is the master, any switch issues here will effect the passenger side as well.
Old 09-27-2007, 08:35 PM
ddnail's Avatar
Dealer : Toyota of Muskogee
2003 Toyota Tacoma
Last Online: 02-24-2010 05:46 PM
ddnail is a splendid one to behold. ddnail is a splendid one to behold. ddnail is a splendid one to behold. ddnail is a splendid one to behold. ddnail is a splendid one to behold. ddnail is a splendid one to behold. ddnail is a splendid one to behold. ddnail is a splendid one to behold. ddnail is a splendid one to behold. ddnail is a splendid one to behold. ddnail is a splendid one to behold.
ddnail's Photo Albums My eBay
It sounds like the drivers side switch panel to me. Check in there before you buy an ignition switch.
AKA..dingdong
Silver 03 Taco Limited TRD 4dr. 4X4 V6 Auto
Extang Tonneau, LineX Liner, 3" Toytec lift with front diff drop, rear Alcan, AAL's w/ degree shims, Procomp shocks front and rear, Locker mod, 285/75/16 BFG's, Code alarm/remote start CA670, Putco Stainless Grill, Several CUSTOM off road pin stripes
Old 09-29-2007, 12:12 AM
Hi Volt's Avatar
Images: 7
An ignition switch would not be the cause of this, you would definately have more things not working as there are a number of circuits tied to the same point. The driver door switch(s) are most likely the cause, perhaps just a loose connector. Try unplugging and replugging each connector and listen for a definite "click" to ensure they lock back correctly.
Old 09-29-2007, 08:43 PM
2004 Toyota Tacoma
This sounds familiar.
Onboard Air
Alarm Mod
RR-Diff lock mod
Toyota Corporate Response to ride issue!!! azsmokey Tundra 133 08-11-2007 09:27 PM
T100 Electrical Issue - Need Help! THarms Out-of-Production Trucks & SUVs 4 07-15-2007 08:34 PM
91 LC electrical issue p7teb7 Land Cruiser 2 07-07-2007 05:38 PM
HELP! 2004 Tundra Quadcab electrical issue (remote start) jungy 1Gen-Tundra 8 12-21-2006 11:57 PM
2000 V8 Tundra - Idol Issue... Electrical?? Faulty battery?? Dogboy420 1Gen-Tundra 6 08-27-2005 11:06 AM
