timing chain cost and is it time?
+ Reply to Thread
Results 1 to 7 of 7
Thread: timing chain cost and is it time?
  1. #1
    Join Date
    Jan 2007
    Location
    pensacola
    Posts
    22
    Liked
    0 times
    Rep Power
    9
    Default timing chain cost and is it time?
    on average what would it cost for me to have a timing chain replaced in a 96 tacoma 2.7 liter 4 cylinder..... also the thing runs absolutely perfect, i just feel it may be time to change at 173,000 miles, how long will one of these chains go?
    yeah it's a titan!.....
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Veteran Member yspert's Avatar
    Join Date
    Dec 2005
    Location
    The Real World
    Posts
    661
    Liked
    12 times
    Rep Power
    1027
    Exclamation Re: timing chain cost and is it time?
    replace the chain if it makes noise at idle. if not, then
    don't. the only time i see the chains needing to be
    replaced is if the oil is not change a lot. should last
    the life of the engine. mine do. yspert
    Graduated from Y to Z status. I only work for "likes"!
  4. #3
    Join Date
    Oct 2007
    Location
    Eastern Ontario
    Posts
    44
    Liked
    0 times
    Rep Power
    8
    Default Re: timing chain cost and is it time?
    My experience is with a 2.4 litre in a '95 4Runner, so the situation may be a little different.
    I replaced the timing chain at about 235,000 km when I could hear it winding up as a sort of counterpoint to the engine's reving. It didn't sound right, although the engine still ran pretty well.
    My friend's a GM dealer mechanic and hadn't done one, so he read up on it and found out about the hidden bolt usually buried in oil at the end of the head (2.4 engine), and successfully removed the old timing chain. It was stretched beyond tolerances, so he put the new one on and replaced the water pump at the same time.
    That's 140,000 km ago so the memory's a bit vague. I think it took him about four hours and cost $250-350 for the aftermarket parts. The job was challenging enough to get a good mechanic's attention, though readily done in an evening.
    When is it time to change the chain? Toyotas have non-interference engines, so it's not as though it's a Honda or an Audi. From what I've seen a worn chain will annoy you with its whirring to the point that you'll change it long before it breaks.
  5. #4
    Supercharged Member HOGWILD's Avatar
    Join Date
    May 2006
    Location
    Albuquerque
    Posts
    3,510
    Liked
    7 times
    Images
    12
    Rep Power
    578
    if it's the 22R this talks about it! Toyota 22R Timing Chain Replacement- ORN
    if it is not broken why break it? Labor is about 90 bucks per hour
  6. #5
    Join Date
    Dec 2005
    Location
    The Real World
    Posts
    661
    Liked
    12 times
    Rep Power
    1027
    you may want to look into the above statement. yspert
  7. #6
    Supporter The Phoenix's Avatar
    Join Date
    Oct 2006
    Location
    TundraSolutions.com
    Posts
    2,495
    Liked
    4 times
    Images
    2
    Rep Power
    142
    The guides usually get worn out before the chain does. That's the annoyance.
    I would get it changed with that many miles on the truck though.
  8. #7
    Veteran Member kathyricks's Avatar
    Join Date
    May 2007
    Location
    Salem
    Posts
    798
    Liked
    4 times
    Rep Power
    9
    The 1983-1995 22R is the only overhead cam engine in Toyotas line up that tends to need a new timing chain mechanism after 150,000 miles or so.
    Thats why on ebay you only see timing chain kit ads for the 22R, but almost never for the Previa and Tacoma.
    yspert is right that your Tacoma chain mechanism should last the life of the engine IF
    you've been changing the oil regularly and not driving abusively (e.g alot of full throttle starts from a dead stop or lugging the engine in too high of a gear when going up hills)
Quick Reply Quick Reply
Register Now
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
