1Gen-TacomaGeneral discussion forum for the 1995 to 2004 Toyota Tacoma.
This is a discussion thread titled "high rpms?? tacoma prerunner v6. whats ur rpms??", within the 1Gen-Tacoma forum, part of the Truck Forums category.
does this sound normal? 3300rpm going 65mph, 3600 rpm around 70mph, and 3800rpm going about 74....the engine doesnt sound like its turning that high...i just bought the truck last week and noticed the tach bouncin with the slightest touch of the accelerator...is this normal???? 2002 prerunner v6
Re: high rpms?? tacoma prerunner v6. whats ur rpms??
Yes..running Stock Tires, Overdrive Is On, Ect Is Off. It Just Seemed Like Hitting Almost 4000rpms Often Seemed A Bit Off Especially After Driving A Ltd 05 Tundra. Thanks For Your Input
That sounds alittle too high, i could be crusing 70-75 and my rpms range from 2100-2500. Are you running 33's or 35's with stock gearing? If thats the case your getting more rpms to keep a certain speed...once you add bigger gears your rpms will drop.
i have all stock gears and tires...265/75/16. the tach gets very sensitive when i slightly step on the accelerator. i dont know if its my cluster thats goin haywire or not. i thought the rpms were a little higher...
it started doing that when i took my cluster off to replace a busted bulb on my gas gauge. i never really paid any attention to the rpms before, but i recall not hitting 4000+ rpms by going70-75 mphs... did i f_ck something up here then????? help!!
what should i do now? everything sounds normal, the engine doesn't sound like its stressin at all...
I would think that something in there is a miss. I know it's a pain, but I'd double check the cluster. Making sure you don't have any loose connections or any bare wires touching.
4 grand at 70-75 is high. If you have access to an OBD2 scanner, the kind that you read engine codes with, you can double check the rpm's with it and see if it's your tach or what. You ought to be able to borrow one from a local parts store.
AKA..dingdong
Silver 03 Taco Limited TRD 4dr. 4X4 V6 Auto
Extang Tonneau, LineX Liner, 3" Toytec lift with front diff drop, rear Alcan, AAL's w/ degree shims, Procomp shocks front and rear, Locker mod, 285/75/16 Nitto's, Code alarm/remote start CA670, Putco Stainless Grill, Several CUSTOM off road pin stripes
