Old 12-11-2007, 12:38 PM
Dealer : Nye Frontier Toyota/Scion
2003 Toyota Tacoma
Last Online: 01-28-2008 04:30 PM
jo-jo is on a distinguished road.
jo-jo's Photo Albums
Default 2003 tac dbl cab slipping
my truck keeps slipping out f drive and reverse if i take my foot off the gas for very long does anyone have an idea of what could cause this?
any help would be great
Jo-Jo
Old 12-12-2007, 06:00 PM
The Phoenix's Avatar
Moderator
Last Online: Yesterday 01:23 PM
Images: 2
The Phoenix's Photo Albums
Default Re: 2003 tac dbl cab slipping
The shifter itself is moving on its own?
Old 12-12-2007, 07:43 PM
2003 Toyota Tacoma
No the shifter doesnt move but like if I am backing up and if I dont give it enough gas it will slip into neutral, same with drive when I come to a stop sign it does the same thing.
Old 12-13-2007, 09:54 AM
Moderator
Images: 2
Does the shifter feel lose like it has some play in it? If the shift cable is lose, it's very easy not to be fully engaged in gear. If it's not that, your tranny has some problems.
Old 09-09-2008, 11:47 AM
Dealer : Phillips Toyota Scion
2002 Toyota Tundra
Last Online: 10-20-2009 07:22 AM
leadoff2 is on a distinguished road.
leadoff2's Photo Albums
I have an '02 Double Cab Prerunner and mine has started doing the same thing, except mine only does it in drive. It'll do it while stopped at a red light and also if I brake but do not come to a full stop and then I hit the gas again sometimes. What did you figure out? I think the shifter cable is just loose on mine... at least I hope.
Old 10-10-2008, 09:59 AM
2002 Toyota Tundra
Anyone have any info. on this? My slipping out of drive seems to happen most when I have to brake hard when coming to a stop and also when the engine is completely warm yet. Really need some advice on this!
Old 10-10-2008, 11:45 AM
Moderator
Images: 2
As I said before, are your shifters moving at all? If not, I would believe the shift cable is loose. Get a friend to sit underneath the truck while you move the shift lever from P to D to find the cable. Look for the adjustment, and tighten it up!
Old 10-15-2008, 10:46 AM
2002 Toyota Tundra
Thanks! No, the shifter isn't moving so it must be the cable... hopefully.
Old 10-15-2008, 03:59 PM
Moderator
Images: 2
Please keep me posted
Old 01-08-2009, 01:25 PM
2002 Toyota Tundra
I recently had the transmission fluid changed at 65,000 miles and the problem is gone now. I didn't know the last time it had been changed so I went ahead and did it. Haven't had a problem w/ it shifting out of gear in 2 weeks. It was better the day the tranny fluid was changed.
Old 01-10-2009, 04:45 PM
Dealer : Priority Toyota
1997 Toyota Tacoma
Last Online: 05-30-2009 11:26 PM
Cobb is on a distinguished road.
Cobb's Photo Albums
I had a 240d benz that did this. New shifter linkage bushing fixed theproblem.
