Stalling out at startup
I hope somebody can help figure this one out. Lately my 2001 Tacoma Prerunner has been stalling out. It will stall out right after I try to start it, the only way I can keep it from stalling is press down on the accelerator. When it gets started it will run very good, except for sometimes when it comes to a stop the rpm's will dip down to 500 rpm. Normally it idles about 650-700 rpm. When the trucks gets running it runs really good.
Yesterday I did some work to the Trucks:
Changed plugs – The old ones where a little worn and had a light tan look to them
Cleaned throttle body – Was just a little dirty
Cleaned mass air flow sensor
Replaced Air filter
Fuel Treatment – Added to the gas a few days ago
After all the work I did to the truck it seems to have more power and runs very smooth, but it will still stall at startup. The stalling only happens after the engine gets warmed up, I'll stop somewhere, then when i try to start it back up it will stall. Also the stalling problem is intermittent.
