Re: yellow fluid drip from rear axle
It's probably gear oil. Try smelling it. Gear oil has a rather pungent smell. You'll definitely want to get that fixed because a new differential/axel is no cheap repair. It's most likely just the washer around the drain plug, or possibly the filler plug if it was overfilled or parked on a steeply angled hill.
Did you recently do any maintenance on the truck that involved a fluid change on the rear diff? Toyota sells new washers dirt cheap.. but you'll have to drain the fluid out of the diff in order to put the washer on(only if it's the drain plug, not the filler). If you just had the fluid changed, catch it in a clean pan of some sort and you can just pump the same stuff back in through the filler hole... and clear off any loose metal that may be stuck on the drain plug which is magnetic.
-2004 Infiniti G35 Coupe 6MT, Diamond Graphite/Graphite, Navigation, Aero Package, Premium, Brembo Brakes with Project Mu B-Force Pads, Z-Tube and Amsoil EA Air Filter, 3/8" Motordyne Plenum, 18" Wheels w/ Falken Fk-452's 245/40/18 - 255/45/18
-2001 Toyota Tacoma Stepside SR5 5-Speed 4X4 with crappy Nerf Bars, Bedliner and Tonneau Cover, Amsoil EA Nanofiber Air Filter, Bridgestone Dueler AT Revo 275/70/16 Rubber, and a ScanGauge II
