Wondering if anyone knows if the plastic/foam thingees that hold the cup firmly in the cup holders in the center console can be replaced. I havent torn into it to see if possible.
Dont know if its the summer heat in Phoenix, but mine have all broken off.
Only complaint after 113K of trouble free miles..........
I dont believe there's a way to replace them, at least I've never seen a way, or even looked deeper into it. I'd think they are only there to keep different size cups from moving around. Using those foam can holders and stuffing them into the cup holder will probably do just as good.
If your talking about the foam things that stick out of the cup holder to hold the cups tight you can replace them. Mine were bad and i found a place that sold them online. For some reason my dealer doesnt show a part number for them. I think I paid 6 for them. Here is the link
Install was easy you just unscrew and unbolt your center counsel and flip it over and those tabs have phillips screws you unscrew. Then put the new ones in and put everything back together in the reverse order. 20 min tops to do everything. One thing to be careful of is overtightening the philips heard screws that hold the tabs into place i tightened one to much and it started poking threw on the other side. But overall easy to do
Cool, thanks.
AKA..dingdong
Silver 03 Taco Limited TRD 4dr. 4X4 V6 Auto
Extang Tonneau, LineX Liner, 3" Toytec lift with front diff drop, rear Alcan, AAL's w/ degree shims, Procomp shocks front and rear, Locker mod, 285/75/16 Nitto's, Code alarm/remote start CA670, Putco Stainless Grill, Several CUSTOM off road pin stripes
Here is the part #s 66995-AD011 x 4.....66995-AD021 x1 ...
Replaced all mine very easy to just unbolt the two bolts after the gear shifter and under the armrest in the lower compartment console comes right off...The new parts are way better design should last very long.
Those are toyotas part #s just go to the dealer cost me around $15.00
