Re: Electrical Problem 2004 Doublecab
well it definetly sounds like you have a parasitic drain, I'd invest in a digital multimeter. It could be many things that are causing the drain on the battery, the battery cable may have corrosion, the battery may have dirt, acid, water, contamanants on the top causing electrons to be able to travel across, there could be a short to ground on a simple little light such as glove box light causing it to stay on when you close it. Just do some searching and investigating and i recommend getting a multimeter, it well come in handy for much more than just this.
"The glass isnt half empty or half full...
its twice as tall as it needs to be"
~How an engineer views life
