Old 01-30-2008, 04:23 PM
Last Online: 03-01-2009 11:23 AM
Tacomasr4me is on a distinguished road.
Tacomasr4me's Photo Albums
Default Whats the name of this part and is it replaceable?
As the title says. the steering part that comes from the rack. With the rubber boot on it. There is some slack in the steering and it is coming from inside that boot area. Is there a bushing or nut I can replace/tighten?
Old 01-30-2008, 04:33 PM
Dealer : Reno Toyota
2005 Toyota Highlander
Last Online: 10-31-2009 11:12 AM
rogernf is on a distinguished road.
rogernf's Photo Albums
Default Re: Whats the name of this part and is it replaceable?
that is a sway bar link. the rubber bushing appears tired. easily replaced,if you can find urethane is better, but rubber is fine. rogernf
Old 01-30-2008, 04:36 PM
That is a sway bar link. the bushing is rubber and easily replaced. rubber is ok,but urethane is better. rogernf
Old 01-30-2008, 04:49 PM
Read the question again. Its the link from the tie rod to the steering rack. What is that called? Its hidden under that boot.
Old 01-30-2008, 04:53 PM
Dealer : Hoselton Toyota Scion
- Other -
Last Online: 09-10-2009 03:56 PM
Xander1281 is on a distinguished road.
Xander1281's Photo Albums
On the ends of the steering rack are inner and outer tie rods. Looks like your problem is with the inner tire rod.
Old 01-30-2008, 05:40 PM
HOGWILD's Avatar
Dealer : American Toyota
2006 Toyota Tundra,
1993 Toyota Truck,
2007 Scion tC
Last Online: Today 08:24 PM
Images: 12
HOGWILD is a splendid one to behold. HOGWILD is a splendid one to behold.
HOGWILD's Photo Albums
http://www.ncttora.com/fsm/05+/data/...a/04500510.pdf
ya need to take boot apart and check the rack where the tie rod connects and pray it is not the rack! tie rods are affordable and racks are not!! Good Luck!!
Old 01-30-2008, 05:45 PM
Thanks for reply
inner tierod is the name of it. Someone else emailed me the name. But mine are tight.
Its coming from the lock on the steering wheel and the rubber bushings holding rack on. I just took it apart and looked at it real good with someone rocking the tire. I am picky about my junk and dont like loose crap. So all is good again.
