Re: '96 5VZ-FE Ignition wires
seems the 3.4L is not an interference engine so breakage would not be engine change, still needs the whole kit changed out when done, idlers x2, seals x2, Timing Belt, water pump,T stat, coolant, tensioner and the 50.00$ OEM wires will do ya just fine for another 150K, not sure if anyone does aftermarket Toyota wires cause they have the boots built in? clean up the Throttle Body if possible with spray and tear it apart and wipe out all the gummy varnish that can't be gotten with the spray!
