Go Back   Tundra Solutions Forum > Truck Forums > 1Gen-Tacoma
1Gen-Tacoma General discussion forum for the 1995 to 2004 Toyota Tacoma.
This is a discussion thread titled ""Lazy" seatbelt retractor", within the 1Gen-Tacoma forum, part of the Truck Forums category.
Old 02-07-2008, 11:07 AM
Dealer : Kalispell Toyota
2007 Toyota Camry HV,
1997 Toyota Tacoma DesertSand
georgie's Photo Albums
Last Online: 09-20-2008 07:53 AM
georgie is on a distinguished road.
Default "Lazy" seatbelt retractor
I have a 97' Taco Extended Cab.
The seatbelt retractor on the drivers side has become very difficult to get to retract the belt. When I unbuckle the belt it won't retract. It just kind of lays in a pile on the rear floor unless I manually feed it back into the retractor.
Is there and way of "rewinding" the retracting spring mechanism to increase the retracting spring tension?
I have taken the truck to my local Toyota dealer but they claim they cant do any adjusting except to replace the whole seat belt mechanism. ($150.00 for the part not including labor to install)
I seem to remember taking my previous Taco to a dealer in another state where I was living at the time and they were able to "rewind" the retracting spring without having to replace the seatbelt.
Any input from Forum members would be much appreciated.
Old 02-07-2008, 06:36 PM
Dealer : Thompson Toyota
1997 Toyota Tacoma,
2003 Toyota Tacoma silver double cab
timmartin's Photo Albums
Last Online: 09-10-2008 12:44 PM
timmartin is on a distinguished road.
Default Re: "Lazy" seatbelt retractor
No idea how to fix it but it's a very common problem
Old 02-11-2008, 09:41 AM
1997 Toyota Tacoma
reader094's Photo Albums
Last Online: 09-01-2008 04:23 PM
reader094 is on a distinguished road.
my 97 does the same thing, wish I could put the passenger side on the driver side.
Old 02-18-2008, 05:56 PM
The Raisin's Avatar
Dealer : Toyota of Puyallup
2007 Toyota Tundra,
2006 Scion xA
The Raisin's Photo Albums
Last Online: 10-10-2008 07:29 PM
The Raisin is on a distinguished road.
I have that problem as well in my 97. Not quit as bad as yours but it is getting there.
Mark
Old 02-25-2008, 01:09 PM
Dealer : Bill Dube Toyota
1997 Toyota Tacoma
woodsailor's Photo Albums
Last Online: 09-23-2008 02:03 PM
woodsailor is on a distinguished road.
It wouldn't be a Toyota without the lazy seat belt retractor!
My 97 does the same thing. Last year the drivers side retractor broke totally just before a long weekend trip so I swapped over the passenger side temporarily. Then paid the dealer about $150 for a new drivers side one, which I installed. The bolts through the floor were pretty rusty and a pain to get out. I recall there didn't seem to be any easy way to take apart the retractor and repair it. A year later the new one is lazy too now.
Old 02-25-2008, 02:13 PM
HOGWILD's Avatar
Dealer : American Toyota
2006 Toyota Tundra,
1993 Toyota Truck,
2007 Scion tC
HOGWILD's Photo Albums
Last Online: Yesterday 09:53 PM
HOGWILD will become famous soon enough.
My 92 Camry had this issue and my 93 PU also has it! would not know what to do without it!
Old 03-05-2008, 03:41 PM
zlathim's Avatar
Dealer : Peterson Toyota
zlathim's Photo Albums
Last Online: 09-17-2008 12:43 PM
zlathim is on a distinguished road.
There has been much discussion on this issue, you can find a bunch of stuff by using the search function. I think the only thing that truly helps is removing some of the material in the opening of the upper seatbelt guide. I think the routine is to pass a piece of sand paper between the guide and the belt making sure the sandy side is toward the plastic and not the belt. Pull back and forth until the sandpaper rips apart, then repeat until there is some slop between the belt and the guide.
Black 2000 Tundra AC 4x4 TRD
Stock everything, just the way I like it.
Old 03-07-2008, 04:05 PM
zlathim,
You know...
I'll bet you're right.
I am going to try the sandpaper fix at my first opportunity.
It does seem that the seatbelt guide is where the belt hangs up the most.
Because the retractor does seem to have enough retract power. It just cant overcome the friction in the guide.
Thanks for the tip.
Old 03-07-2008, 04:11 PM
zlathim,
You know.....I think you're right.
The seatbelt guide does seem to be where the seatbelt hangs up the most.
The retractor seems to have the retract power, it just cant overcome the friction in the seatbelt guide.
Thanks for the tip.
Old 03-10-2008, 10:13 AM
zlathim's Avatar
No problem georgie- I hope it helps.
Old 03-14-2008, 04:04 PM
I tried the sandpaper routine and it seemed to free up the seatbelt guide so the belt would pull through it easier.
The fix has helped with the retract. Probably as good as it's going to get outside of a new belt /retractor.
Again thanks for the tip......
Old 03-14-2008, 05:05 PM
Dealer : Gulf Coast Toyota
- Other - 1993 T-100 SR5
BamZipPow's Photo Albums
Last Online: 10-09-2008 02:23 AM
BamZipPow is on a distinguished road.
Send a message via AIM to BamZipPow Send a message via Yahoo to BamZipPow
Yer looking fer this seatbelt fix...
You could even handwash yer seatbelt and see if it makes a diff...
Just undo the pillar pivot bolt and git yer bucket of sudsy water and wash the belt. Rinse. Blot dry as possible. Rebolt the pillar pivot back in place...yer good to go! Just make sure you don't drip water down inside the retractor...
