Old 02-15-2008, 02:38 PM
Dealer : Ensign Toyota
1998 Toyota Tacoma
Last Online: 02-26-2008 01:33 PM
paradox001 is on a distinguished road.
paradox001's Photo Albums
Question High Idle - Can't seem to solve it
Well, I've searched around the forums here and other places on the web for things to try with no luck so far! Stumped
I have a 1998 Tacoma 3.4L with about 99k miles. It started throwing a check engine light with code P0505 which means idle control system malfunction. Then, it started to idle too high (1800-2000rpm).
What I did:
Cleaned Throttle body
Cleaned IAC valve and replaced gaskets
Checked IAC valve operation and resistance according to repair manual
Checked throttle position sensor resistance
Throttle valve is in fully closed position when it is idling
Looked around for dry/leaky air hoses
After doing all this it worked fine for a day...... Then started right back with idling high, however it has NOT thrown a P0505 code since doing these things.
Anyone have any ideas??
Old 02-15-2008, 11:22 PM
The Phoenix's Avatar
Moderator
Last Online: 11-13-2009 03:17 PM
Images: 2
The Phoenix's Photo Albums
Default Re: High Idle - Can't seem to solve it
I wonder if it has something to do with the initial startup for high idle that warms the catalytic converters. You checked alot of the main culprits though. I'm stumped.
Old 02-17-2008, 08:15 PM
1998 Toyota Tacoma
Yep, not sure what is going on. Also checked the PCV valve and cleaned the MAF sensor.
Since it worked fine for a day after I cleaned the IAC valve, i'm tempted to open it back up and see if that valve is stuck open now or something
Old 02-18-2008, 05:31 PM
Moderator
Images: 2
The IAC can act up. I would replace it as it's not that expensive.
Old 02-19-2008, 01:06 PM
1998 Toyota Tacoma
It worked fine when I tested it but I'll have to take off the throttle body again and test the valve another time. I'd still like to avoid a $220 part replacement if possible
Old 02-19-2008, 05:41 PM
HOGWILD's Avatar
Dealer : American Toyota
2006 Toyota Tundra,
1993 Toyota Truck,
2007 Scion tC
Last Online: Yesterday 08:02 PM
Images: 12
HOGWILD is a splendid one to behold. HOGWILD is a splendid one to behold.
HOGWILD's Photo Albums
Have ya ever changed PCV or checked the hoses for leaks or loose as in popped off?
Old 02-26-2008, 01:33 PM
1998 Toyota Tacoma
Ok, it was the IAC valve. Weird since it had worked fine when I cleaned and tested it, but unplugging the power to it brought the idle right down.
So I replaced it with an ebay used one and it works great now!
Old 02-26-2008, 11:42 PM
Moderator
Images: 2
Very nice! The Phoenix FTW!
Old 02-26-2008, 11:44 PM
D&M D&M is offline
Dealer : Longo Toyota
2005 Toyota Tundra,
2002 Toyota Tacoma,
- Other - 2006 Acura RSX
Last Online: 08-02-2008 06:12 PM
D&M is on a distinguished road.
D&M's Photo Albums
What is this?
Thanks.
Old 02-27-2008, 09:45 AM
Moderator
Images: 2
Originally Posted by David Neal Minnick View Post
What is this?
Thanks.
Idle Air Control valve. See google for several descriptions and pictures. IAC Valve - Google Search
