Old 02-16-2008, 11:00 AM
Dealer : Burlington Toyota
1999 Toyota Tacoma
Last Online: 02-22-2008 05:18 PM
rutridr is on a distinguished road.
rutridr's Photo Albums
Default signal problems
hi there i have a 99 tacoma i am having problems with my right signal when i turn it on it works fine but the interior dash lights up as it blinks and same with the radio and the the exterior lights they are all very dim but none the less they still light up i also noticed that some times when i push the brake the dash lights also turn on and off as i release the brake any ideas? i have already changed all the bulbs dont know what else i can do ??
Old 02-16-2008, 12:44 PM
Dealer : Voss Toyota
2001 Toyota Tacoma DC S-Runner,
2004 Toyota Tacoma BSP S-Runner
Last Online: 11-20-2009 10:21 AM
EnolaGaia is on a distinguished road.
EnolaGaia's Photo Albums
Default Re: signal problems
Your interior dash illumination is powered off the taillight circuit. However, the taillight circuit is different from the stop light (brake light) and turn signal / hazard light circuits.
This leads me to suspect there's a slight short circuit somewhere that results in the taillight circuit being 'cross-juiced' when either the turn signal or brake lights are activated.
Since these circuits have nothing to do with the headlights and it occurs with only the right turn signal (if I understand correctly), my first suspect would be a wiring fault (slight short) in either the right rear combination light assembly or the wiring leading to it.
The turn signal - to - taillight / dash cross-activation might also (conceivably) occur if there were a similar 'short' in the light / signal control stalk on the left side of your steering column (or maybe the switch unit attached to it). However, this wouldn't explain how the brake light circuit was also activating your taillight / dash circuit.
I'd start with wiring, etc., in the vicinity of the right rear light.
2000 model year wiring diagrams (same generation as your 1999) can be accessed at:
Sitemap
or
Sitemap
Hope this helps ...
Old 02-16-2008, 04:23 PM
yspert's Avatar
Dealer : Rice Toyota
Last Online: 10-30-2009 10:49 PM
yspert is on a distinguished road.
yspert's Photo Albums
Exclamation Re: signal problems
wrong bulb, bad socket, or poor trailer light wiring. i have seen
this when someone puts a "one filament bulb" in a "two filament socket". the one filament bulb "tit" will touch both pins down in the socket. so, when you send power down the brake pin, the power flows into the park light pin and causes the whole parking light circuit to power up. yspert
Graduated from Y to Z status.
Old 02-19-2008, 05:30 PM
1999 Toyota Tacoma
i replaced all the bulbs checked all the harnesses all the wires i cant see anything wrong is there something else i could check a relay? a switch? iam getting really desparate thanks for your help iam lerning more about the truck every day
Old 02-20-2008, 09:58 AM
Did you disconnect the wiring to the taillights entirely to see how it behaved? Visual inspection isn't sufficient for finding a short / fault.
Old 02-21-2008, 11:17 AM
yspert's Avatar
good start. also, remove one bulb at a time and see if the problem goes
away. yspert
Old 02-21-2008, 11:45 PM
v6er's Avatar
Dealer : Brown's Charlottesville Toyota
Last Online: 10-19-2009 09:02 PM
v6er is on a distinguished road.
v6er's Photo Albums
sounds like you have a short to power
"The glass isnt half empty or half full...
its twice as tall as it needs to be"
~How an engineer views life
