Custom Search
Welcome to the Tundra Solutions Forum forums.
Go Back   Tundra Solutions Forum > Truck Forums > 1Gen-Tacoma
The Tire Rack- Revolutionizing Tire Buying
Click here for the Best Buy Homepage
Cake Batter Muscle Milk, Exclusive Flavor
Bad Credit? No Credit? No Problem!
1Gen-Tacoma General discussion forum for the 1995 to 2004 Toyota Tacoma.
This is a discussion thread titled "Disable the ABS on a 2003 Tacoma", within the 1Gen-Tacoma forum, part of the Truck Forums category.
Old 02-24-2008, 03:22 PM
Dealer : Bredemann Toyota
2003 Toyota Tacoma
john01374's Photo Gallery
Last Online: 05-24-2008 01:14 PM
john01374 is on a distinguished road.
Default Disable the ABS on a 2003 Tacoma
Guys I'm looking for a way to disable the ABS on my 03 taco 4x4 trd. I've had enough of the computer taking over and pulsing all the way to the bottom of a small hill i have to drive eveyday. Not to mention all the near misses due to the system releasing the brakes. I lived with the problem for a long time thinking it was just the junk stock tires. I replaced all four tires with Dueler AT Revo's a week ago and the problem is the same. I have a buddy with a taco and Blizakks. We'll pulled those and put them on my truck, Same thing (buddies taco does same thing. That's why he bought the Blizakes). The ABS system on this truck stinks and toyota says it's working noramlly. Here's the senerio. Pull out of my drive way, drive about 5 mins. Slow to about 15mph and crest the hill that leads down to a stop sign. The hill is appox 3 blocks long and it takes every bit of two blocks to stop from 15 mph. Now i tried the same thing (same day) in my old beater front drive lebaron with $30 pepboys tires with 70K miles on them and no ABS. Not a problem, stops in a few car lengths from 30mph. I don't want to have the conversation about if i should or should not disable the ABS. It's getting done. I'm just asking if anyone here knows a simple and easyway to do it. I know the 05+ owners have a way to tap into the fuse block and run a switch. Anyone know how to do it on the 2003 model?
Old 02-24-2008, 06:24 PM
wirelessf's Avatar
Dealer : Waipahu Toyota
2001 Toyota Tundra,
- Other - 1990 Toyota 4Runner
wirelessf's Photo Gallery
Last Online: Today 04:12 PM
wirelessf is on a distinguished road.
Default Re: Disable the ABS on a 2003 Tacoma
The only way to disable your ABS is to pull out the ABS fuses in the fuse box under the hood. I'm not sure about runnng a switch to the fuse but simply pulling the fuses is easier.
Yours might have one or two ABS fuses if it's two or four wheel ABS.
Old 02-24-2008, 09:04 PM
2003 Toyota Tacoma
cool. i know there is one fuse under the hood. If there is more than one, any idea where it might be located?
Old 02-24-2008, 09:39 PM
The Phoenix's Avatar
The Phoenix's Photo Gallery
Last Online: 07-02-2008 06:06 PM
Should be in the fusebox with the rest of the fuses. You are going to have a ABS light on your dash if you do remove the fuse though.
Old 02-25-2008, 11:26 AM
2003 Toyota Tacoma
I can live with an ABS light. I can't live with the brakes not working. I'm considering buying an FJ for the GF. Any idea if they have the same ABS problems as the Taco's?
Old 02-25-2008, 08:43 PM
Burger Steak & Eggs's Photo Gallery
Last Online: Yesterday 11:50 PM
Burger Steak & Eggs is on a distinguished road.
I agree with your observations. On slippery surfaces when I brake, my Tundra slides forward as though the brakes are not applied at all, thanks to ABS.
Old 02-26-2008, 08:37 AM
2003 Toyota Tacoma
So this is more wide spread than just the Tacoma. Well we just got about 6 inches of snow here in chicago overnight. I've been thinking of getting the GF an FJ. Looks like a good time for a test drive. We're not buying it if it acts like my Taco. This thing is dangerous.
Old 02-26-2008, 10:39 PM
This is one of those times where friction from skidding would probably work better than the brakes pulsating very fast on a slippery surface. I can recall several times where trying to stop on snow takes longer with ABS versus non. Boy I miss my 02 Standard Cab Tacoma.
Old 02-27-2008, 08:21 AM
2003 Toyota Tacoma
Pulled the main fuse in the fuse block under the hood and it seems to have done the trick. I do have to live with the ABS light but a piece of black tape hides it fairly well so...........
Old 02-27-2008, 08:46 AM
I believe you can remove the bulb in the cluster if you would like as well.
Old 02-27-2008, 10:08 AM
tarzan's Avatar
Dealer : Gateway Toyota Edmonton
2003 Toyota Tacoma
tarzan's Photo Gallery
Last Online: 03-29-2008 05:59 PM
tarzan is on a distinguished road.
I have never had any issues on road with my ABS. Here in Alberta we see our fair share of slick roads. The only time the anti-lock has been a problem is off roading as it tends to let the wheels continue to dig when the truck has lost momentum. I will be disabling the ABS in 4hi. I know that in 4low it is deactivated. What I was saying before my ADD kicked in lol is that ABS has always been helpful to me on the street. Maybe i'm just lucky that way.
Old 05-05-2008, 06:59 PM
Dealer : Crown Toyota Scion
2003 Toyota Tacoma
Goot7777777's Photo Gallery
Last Online: Today 09:06 AM
Goot7777777 is on a distinguished road.
Default 2003 Tacoma
My ABS light is on and the steering wheel shakes when I brake. Does anyone know what the problem is and how to fix it? Thank you in advance.
2003 Toyota Tacoma SR5 Pre Runner.
Old 05-05-2008, 08:48 PM
Dealer : Harrelson Toyota
2006 Toyota Tacoma
tacomaman06's Photo Gallery
Last Online: 06-29-2008 03:26 PM
tacomaman06 is on a distinguished road.
Default Re: My Abs Light Is On And The Steering Wheel Shakes, What Do I Do?
Originally Posted by Goot7777777 View Post
My steering wheel shakes when I apply the brakes. My ABS light is on. Does anyone know what the problem is and how to fix it? Thank you in advance.
sounds to me like one of your abs sensors is bad. possibly a front one too. you may have to unplug each one individually and drive a bit and see which one it is, as im pretty sure an obd2 code reader wont read the abs codes....but i could be wrong. i would just unplug and see what happens, than you can replace accordingly if that is indeed the problem.
Old 05-07-2008, 10:28 AM
p nut's Photo Gallery
Last Online: 06-21-2008 01:59 PM
p nut is on a distinguished road.
^^ Steering wheel shaking is probably due to warped rotors. Real simple to change out. Just go to Autozone and get some duralast rotors. They have a 2 year warranty, so if they ever warp, you can take them in for new ones. Also, pick up a set of ceramic pads while you're there, too.
The ABS light could be a damaged sensor. You will need to have the code pulled. Usually, only dealerships carry the ABS scan tool, and they charge around $70 to use.
Old 05-07-2008, 10:31 AM
FJC's ABS and ATRAC systems are more aggressive than a 4Runner/Tacoma. Still not sure if that will aleviate the problem, but at least you don't have problems with the TRAC system. I had that on my 02 4Runner, and if there was any slippage detected (even the slightest), the computer will cut the power to the engines immediately. Scary when trying to make a turn with a little bit of snow on the road and there is a train of cars coming towards you!
Anyway, did you end up getting an FJC?
Bookmarks
TundraSolutions.com and the TundraSolutions.com logo are among the registered trademarks of Tundra Solutions, Inc.
Questions? Please use the Contact Us link or call (559) 323-5444. Other websites: DealerHunter JPV Photography
