Old 04-11-2008, 12:44 AM
blkcruiser's Avatar
Dealer : Tracy Toyota
2002 Toyota Tacoma dbl cab
Last Online: 04-16-2008 06:21 PM
blkcruiser is on a distinguished road.
blkcruiser's Photo Albums
Default help!overheating
i have a 2002 dbl cab 4 cyl auto. while driving on the freeway i noticed my temp gauge was beyond the red line, i immediately pulled over and let it cool down. there were no leaks fan belts ok. after it cooled down it was ok for the next 15 miles until i turned on the ac-then it went close to the red line again. i replaced the thermostat-no change...
anybody got any sugestions?
p.s.
ac still functions very good
Old 04-11-2008, 03:11 AM
2XOverhead's Avatar
Moderator
Dealer : Toyota Scion of Santa Monica
2002 Toyota Tundra V8 SR5 TRD
Last Online: 11-18-2009 11:10 PM
2XOverhead will become famous soon enough. 2XOverhead will become famous soon enough.
2XOverhead's Photo Albums
Default Re: help!overheating
The obvious question would be are you sure there's enough coolant. I know you said you found no leaks, but did you pressure test it?
MODS: Oversized Drain Plug.
DIY: ATF Flush, w/ Pics.
DIY: Coolant Flush, w/ Pics.
Coming Soon?
Old 04-11-2008, 07:36 AM
JRE56's Avatar
Dealer : Spirit Toyota
1997 Toyota Camry
Last Online: 11-24-2009 05:44 PM
JRE56 is on a distinguished road.
JRE56's Photo Albums
Check your fan.
Old 04-11-2008, 08:00 AM
The Phoenix's Avatar
Moderator
Last Online: 11-24-2009 01:23 PM
Images: 2
The Phoenix's Photo Albums
So as of now, it seems your only get your overheating when you turn the A/C on?
Originally Posted by JRE56 View Post
Check your fan.
Believe it or not the fan doesn't do much for you on the freeway.
Old 04-13-2008, 10:14 PM
Dealer : Star Toyota
1998 Toyota T100 SR5 2WD auto,
1996 Toyota T100 4cyl auto,
2001 Toyota Camry 4cyl auto moon roof,
- Other - 1985 Celica GTS conv
Last Online: Yesterday 08:53 PM
BamZipPow is on a distinguished road.
Send a message via AIM to BamZipPow Send a message via Yahoo to BamZipPow BamZipPow's Photo Albums
What was the approximate temp outside? Going up a hill? Did you have any heavy loads in the back? Any passengers? When was the last time you had yer AC checked? When was the last time you had yer radiator checked and changed/flushed? Did you check yer radiator fins? How about them radiator hoses? Lot of different things to check...
Is yer truck an auto? Do you have an auxillary cooler on yer tranny? Is the transmission fluid good? Is it at the proper fill level?
When you pulled over, was the overflow bottle bubbling? If not...maybe yer sender/gauge might be wrong. You could test yer temp sender to make sure it's correct.
Does it redline when yer sitting still and with the AC on? Do you have a clutch fan or electric fan?
Old 04-16-2008, 05:06 PM
Dealer : Toyota of Paris
2006 Toyota Avalon
Last Online: 07-10-2008 07:35 AM
Mike Murrell is on a distinguished road.
Mike Murrell's Photo Albums
Plugged radiator, debris on radiator fins; weak water pump.
Any water in your oil?
Mike Murrell
