Old 04-11-2008, 08:13 PM
Dealer : West Herr Toyota Scion
2003 Toyota Tacoma
Last Online: 04-13-2008 09:58 PM
jmoseler is on a distinguished road.
jmoseler's Photo Albums
Default 2003 Tacoma; interior leaking into floorpan on drivers side only.
I have an ocasional to regular water leak into the interior drivers side of my Tacoma. The water pools up in the floor pan and I get to sop it up with full size towels. And, then I get the ocasional horn shorting out for a really long burst, until I'm able to pull over and yank out the fuse. When there's no more heavy rain/snow, no problems.
I've seen some posts in reference to the '05 Tacoma having a similar leak with an associated TSB, but nothing for the '03.
Any ideas for a fix? Or, does anyone have an repeated instance?
Old 04-13-2008, 09:32 PM
Dealer : Star Toyota
1998 Toyota T100 SR5 2WD auto,
1996 Toyota T100 4cyl auto,
2001 Toyota Camry 4cyl auto moon roof,
- Other - 1985 Celica GTS conv
Last Online: Yesterday 08:53 PM
BamZipPow is on a distinguished road.
Send a message via AIM to BamZipPow Send a message via Yahoo to BamZipPow BamZipPow's Photo Albums
Default Re: 2003 Tacoma; interior leaking into floorpan on drivers side only.
Did you have yer windshield replaced anytime ago? Could be a lot of different things. Vent. Grommets.
Yer gonna have to have someone help you by looking fer the leak while someone is running the hose. Be methodical...take yer time. See if you can see spot any water drip tracks before you start. You could dust/blow some corn starch underneath yer driver's side and run the water and see where the tracks lead...
Old 04-14-2008, 09:30 AM
Dealer : Voss Toyota
2001 Toyota Tacoma DC S-Runner,
2004 Toyota Tacoma BSP S-Runner
Last Online: 11-24-2009 06:50 PM
EnolaGaia is on a distinguished road.
EnolaGaia's Photo Albums
There was a revised TSB BO026-00 that addressed leaks in the upper cowl or side cowl seam. It was listed as applicable to 1995.5 - 2004 Tacomas.
This doesn't automatically mean your leak is the same issue, but it's something worth knowing ...
Old 07-30-2008, 10:58 PM
Dealer : Jay Toyota Scion
2000 Toyota Tacoma,
2005 Toyota 4Runner Sport Edition 4WD
Last Online: 07-31-2008 09:12 AM
medic2230 is on a distinguished road.
medic2230's Photo Albums
I had a cb antenna running out the grommet behind the drivers side in the rear of the cab and one time the wire got pulled tight and the water would run down the wire and through the grommet into the cab. A little silicone fixed that problem. Nothing like that small and the sloppy feeling of water under your feet through the carpet. I stripped the cab completely and hung the carpet up to dry and then put it all together again and no smell or anything. Good luck on finding the leak.
Murph
LinkBack to this Thread: http://www.tundrasolutions.com/forums/1gen-tacoma/130128-2003-tacoma-interior-leaking-into-floorpan/
Posted By For Type Date
2003 Tacoma; interior leaking into floorpan on drivers side only. - Tacoma World Forums This thread Refback 04-28-2008 01:57 PM
