Tacoma: Check engine light - Code P0171
+ Reply to Thread
Results 1 to 11 of 11
Thread: Tacoma: Check engine light - Code P0171
  1. #1
    Join Date
    Aug 2002
    Location
    Colorado Springs, CO
    Age
    50
    Posts
    46
    Liked
    0 times
    Rep Power
    14
    Default Check engine light - Code P0171
    On my 99 Tacoma (V6 with 40k miles), I've had a check engine light coming on and off. It's on at the moment, ran it by Autozone, and they pulled a P0171 code.
    Noticed in Lon's garage that a 171 can be:
    - air induction system
    - injector blockage
    - Mass Air Flow meter
    - engine coolant temp sensor
    - Heated oxygen sensor (bank 1, 2 sensor 1)
    Before I proceed with replacing the oxygen sensor, should I replaced the Mass Air Flow meter? Exactly where is this sensor located, and what does it look like?
    TIA!
  2. Remove Advertisements
    Toyota Tundra Forum
    Advertisements
  3. #2
    Supporter usmc grunt's Avatar
    Join Date
    Dec 2003
    Location
    Pearland, TX
    Posts
    30
    Liked
    1 times
    Rep Power
    12
    Default P0171 Issue
    I have had my engine light go go and off for about 20k and up until today the dealers haven't been any help. I should have pressed the issue earlier. But I just rolled 60k on my '02 (with the K&N air filter system) and the damned light came on again. This time the mechanic at the dealer said it was the P0171 code which meant it could be the K&N tube intake as it had a design flaw. They traded my old tube for the new one which has a restriction before the MAF which supposedly reduces the volume of air flowing over the sensor. They said that works most of the time. However, after hooking it up to the computer he said it really was the MAF because the sensor was still sending the "Too Lean" signal. So I'm going to try the MAF and I'll let you know how it goes. $115 bucks and a prayer.
    BTW the MAF sensor is a rectangular plug that is attached to the air intake by two screws at opposite corners of the sensor. It is about 1x2 inches and has a wiring plug attached to it and should be visible as soon as you lift the hood. Try your best to keep it as clean as possible. Good luck and let me know what you find out.
  4. #3
    Leader of Group Evil DevinSixtySeven's Avatar
    Join Date
    Oct 2001
    Location
    Snowy Highlands
    Posts
    11,134
    Liked
    747 times
    Images
    22
    Rep Power
    14113
    before you replace the maf, try cleaning it with a cotton swab and some rubbing alcohol.
    -sean
    GFX by FreedomEagle50
    1-Gen Tundra Offroad Technical FAQ Index
    Manual Hubs
    OB's cup size: 36DD
    "some people will call you stupid but its worth a try because i know i also want one more inch."--SouthernTundraSC
  5. #4
    Join Date
    Aug 2002
    Location
    Age
    50
    Posts
    46
    Liked
    0 times
    Rep Power
    14
    Thread Starter
    Default Thanks!
    Didn't have the time to service this one myself, dealer took care of it and it turned out to be the MAF.
    Appreciate the help anyway.
  6. #5
    Join Date
    Dec 2003
    Location
    Pearland, TX
    Posts
    30
    Liked
    1 times
    Rep Power
    12
    Default MAF Gasket?
    I have the new MAF from Toyota but the new part doesn't have a gasket like the original part. Other than that they are identical. What gives? The dealer says there is no gasket on the replacement part due to it being manf. in US, but the part looks exactly like the original including the "Hitachi". I am a bit skeptical about the knowledge of the dealer (which seems a bit odd). He recommended silicone. Are there any suggestions as to what I should use?
  7. #6
    Junior Member BruceTS's Avatar
    Join Date
    Nov 2003
    Location
    Granada Hills CA
    Posts
    62
    Liked
    0 times
    Rep Power
    12
    The MAF sensor has an "o" ring, but since your running the K&N kit they have a gasket, so you'll have to contact K&N for a replacement.
  8. #7
    Join Date
    Apr 2003
    Location
    galveston,tx
    Posts
    9
    Liked
    0 times
    Rep Power
    0
    Default p0171 and k&n
    Hi there guys,
    for all of you getting the p0171 code and have a K&n filter just like the previous person said clean the maf with either cotton swabs and alcohol or spray brake cleaner (one that wont leave a residue) into the maf. The oil from the filter is coming off and sticking to the hot wire inside the maf and throwing off the maf. Give this a shot before throwing your money away on a new maf. This also applies even if you dont have a k&n but there is a leak after the filter dirt will build up on the wire.
  9. #8
    Join Date
    Dec 2003
    Location
    Pearland, TX
    Posts
    30
    Liked
    1 times
    Rep Power
    12
    Default Cleaning MAF
    I already purchased a new MAF before trying to clean the old one, but out of curiosity I decided to try the alcohol and cotton swab. It worked and was easy, you just have to be careful because the wires are pretty thin and fragile. My mileage imprved about 2 mpg on the highway (about the same in town). Thanks for all the help. I guess I have a spare for when my old MAF finally does crap out.
  10. #9
    Join Date
    Feb 2004
    Location
    Corpus Christi, Tx
    Posts
    2
    Liked
    0 times
    Rep Power
    0
    Thumbs up SurfRatCC
    Quote Originally Posted by usmc grunt
    Hello everyone-
    New guy on the block with what sounds like is a similar problem. I have a 2001 DoubleCab Tacoma/TRD. Put in a K&N air filter about 7 months ago and instantly saw a difference. I dusted a few Mustangs off the line myself. Here is my question. Recently got a check engine light myself and took it in. Tech tells me it is the Fuel/Oxygen sensor and it needs to be replaced. Talking with my neighbor(a Tundra owner) -- says this is characteristic and that I could get on the site and find a "How to" with parts #s and so forth. That is what I am looking for. Any information or direction would be super cool!! SurfRatCC
  11. #10
    Join Date
    Dec 2003
    Location
    Pearland, TX
    Posts
    30
    Liked
    1 times
    Rep Power
    12
    Default O2 Sensor?
    My Yota Master at the dealership said my error was an O2 sensor error. I had my O2 sensor replaced and the light stayed off for about three weeks. Then it came back on. I checked the paperwork for the O2 sensor replacement and it indicated code P0171 (evidently a Mass Air Flow sensor error, not an O2 sensor error). Thats when I started asking questions on this forum.
    Toyota did give me a replacement K&N Intake Tube (I originally purchased my filter system at the dealership) and swabbed my MAF wires with an aloholic Q-tip. Everythings been great so far (about three months without an issue).
    Good luck!
    Praise God and pass the ammo!
    USMC Grunt
  12. #11
    Join Date
    Feb 2004
    Location
    Corpus Christi, Tx
    Posts
    2
    Liked
    0 times
    Rep Power
    0
    Default O2 Sensor
    Good luck!
    USMC Grunt
    Thanks for the info and quick response. I completely agree with your quote. My dad was 31 years military!!! Sempr Fi
    Later
Quick Reply Quick Reply
Register Now
Your postal zip code.
Where you live.
Log-in
Human Verification
Posting Permissions
  • You may post new threads
  • You may post replies
  • You may not edit your posts
