Old 04-21-2008, 09:38 AM
Dealer : Toyota of Chula Vista
2008 Toyota Tundra Timberland TRD Ltd.
Last Online: 02-03-2009 06:34 PM
SanteeRuss is on a distinguished road.
SanteeRuss's Photo Albums
Default Brake Pad clip questions!!!
I have a 1998 Tacoma and just found out that I'm missing the disk brake pad clips. I changed the pads a few months ago (115K miles & 3rd. set of pads) and there weren't any clips. The first brake job was done at Pepboys & I suspect they didn't replace the clips. I now have a rattle when I go over an uneven surface and not applying brake. My questions are:
1. How much do the clips run & are they hard to put on?
2. Will they still work with aftermarket pads, or only w/ OEM?
Thanks!!
Russ
Old 04-21-2008, 12:59 PM
The Phoenix's Avatar
Moderator
Last Online: 11-13-2009 03:17 PM
Images: 2
The Phoenix's Photo Albums
Default Re: Brake Pad clip questions!!!
The clips shouldn't be too bad. They should work with aftermarket pads too.
Old 04-21-2008, 03:03 PM
Thanks, I'll drive my the stealership and pick up a set. I may have to brouse a Chiltons or Haynes to see how they go on though..
Old 04-21-2008, 06:02 PM
Moderator
Images: 2
2003 Toyota Tacoma
It's for an 03 tacoma, but the braking systems should be very close if not identical. They only changed body styles in the Tacoma from 95-04.
