Old 05-16-2008, 04:59 PM
Dealer : Stevens Creek Toyota
Last Online: 11-14-2009 02:03 AM
Tim Mc is on a distinguished road.
Tim Mc's Photo Albums
Default Speedometer Calibration
I have a '99 Taco with a 2.7l and 5-speed 4WD. Wonderful truck except the speedo is off by about 10%. Is there a fix for this or do I have to live with it. Were the speedo's electronic in '99 or still gear driven?
Thanks for the help.
Proud TACO Owner.
Old 05-16-2008, 05:54 PM
imjin's Avatar
ΜΟΛΩΝ ΛΑΒΕ
Dealer : McGeorge Toyota
Last Online: 11-20-2009 08:24 PM
Images: 66
imjin is a splendid one to behold. imjin is a splendid one to behold. imjin is a splendid one to behold.
Send a message via AIM to imjin imjin's Photo Albums
Default Re: Speedometer Calibration
Did you put larger tires on it or regear? If so, the Truspeed Calibrator will fix it for both of those mods. Install is super easy, but takes a little time with removing the gauge cluster and soldering the calibrator into the speed sensor wire. It's listed as being available for the 1992 - 2005 Tacoma, so it should be fine to install it.
Check out this thread on how the install went on a few 1st Gen Tundras. The principals are the same, but your wiring is going to be a bit different. Before you rip into it, shoot mustang67408 a PM or email with your truck specs (year, make, model) and he can probably give you the exact speed sensor wire you need to tap into.
Old 05-19-2008, 02:40 AM
Thanks imjin
This is the type of information I was looking for.
'99 Taco owner
