Old 06-03-2008, 04:27 PM
Dealer : Kalispell Toyota
2007 Toyota Camry HV,
1997 Toyota Tacoma DesertSand
Last Online: 07-28-2009 04:23 PM
georgie is on a distinguished road.
georgie's Photo Albums
Default Cigarette Lighter Receptacle
I have a 1997 Tacoma.
I would like to have the cigarette lighter receptacle "hot" all the time for a cell phone accessory.(Currently it's only "hot" when the ignition switch is in the run or accessory position)
Can any one tell me which wires to switch around on which fuse block so that I can accomplish this?
Thanks'
Old 06-04-2008, 05:01 AM
JRE56's Avatar
Dealer : Spirit Toyota
1997 Toyota Camry
Last Online: Yesterday 05:47 PM
JRE56 is on a distinguished road.
JRE56's Photo Albums
Default Re: Cigarette Lighter Receptacle
Thanks'
If you want to do a quicky you could cut the wire to the lighter,tape the end, splice another wire from the lighter to your stereo yellow constant wire and put a 10 amp fuse inline.
Old 11-18-2008, 05:39 PM
Ney's Avatar
Ney Ney is offline
2004 Toyota Tacoma
Last Online: 08-19-2009 10:20 PM
Ney is on a distinguished road.
Ney's Photo Albums
Thanks'
I know this is a pretty old post, but...
Toyota Tacoma Cigarette Lighter Modification
Old 11-26-2008, 09:10 AM
The Phoenix's Avatar
Moderator
Last Online: 11-13-2009 03:17 PM
Images: 2
The Phoenix's Photo Albums
IIRC, the cigarette lighter has its own power source, just needs a "switched" power source for it's relay, and using the suggestion above would do it.
Old 12-09-2008, 03:42 PM
Thanks folks for the tip!!!!
I want to give it a try
What gauge wire should be used for the jumper?
Thanks again.....
Old 12-11-2008, 05:30 AM
JRE56's Avatar
1997 Toyota Camry
Looking at the pics. I would say about 12 or 14 should do it.
