Old 07-18-2008, 10:22 AM
T2D2's Avatar
Dealer : Performance Toyota Memphis
2004 Toyota Tacoma
Last Online: 10-06-2009 07:09 PM
T2D2 is on a distinguished road.
T2D2's Photo Albums
Default 04 Tacoma Brakes Questions
I have a 2004 Tacoma 4X4 Double Cab Limited edition V6 I am looking to replace the brakes on. I have been doing some reading and it appears that Brembo blank rotors and OEM or Hawk pads seem to be the recommended combination.
Question 1: Does anyone have any alternative recommendations for rotors and pads? Where would you buy them online or offline?
Question 2: Does my truck have VSC? (This is being asked when choosing the correct brakes/rotors at some online sites)
Thanks in advance for the assistance!
Old 07-18-2008, 11:39 AM
Dealer : Voss Toyota
2001 Toyota Tacoma DC S-Runner,
2004 Toyota Tacoma BSP S-Runner
Last Online: 11-20-2009 10:21 AM
EnolaGaia is on a distinguished road.
EnolaGaia's Photo Albums
Default Re: 04 Tacoma Brakes Questions
2004 was the only pre-2005 year in which the VSC/TRAC system was available as an option. It was only available on V6 XtraCab and Double Cab 4X4 / PreRunner models.
If you have the VSC/TRAC system there should be a switch (probably labeled 'Auto LSD', as with the 2005+ Tacomas) on the lower left dash between your steering column and the dash light dimmer knob.
The switch is illustrated in your Owners Manual.
Old 07-21-2008, 08:51 PM
The Phoenix's Avatar
Moderator
Last Online: 11-13-2009 03:17 PM
Images: 2
The Phoenix's Photo Albums
Hawk pads and brembo rotors wouldn't work bad at all together. Do you really need the increase? Standard pads/rotors work pretty well on these trucks unless you're excessively using them.
