Old 07-21-2008, 09:26 PM
Dealer : DCH Freehold Toyota Scion
2002 Toyota Tacoma
Last Online: 11-19-2009 03:55 PM
shift96 is on a distinguished road.
shift96's Photo Albums
Default Transmission cooler
How do I know if I have one? I have an 02 TRD SR5 V6. Didn't come with a hitch or trailer plug but it has a green fan clutch. It also has a cooler mounted in front of the radiator but it seems to have only A/C lines going to and from it. Any thoughts? I want to pull a 6x10 enclosed trailer that weighs about 1100 or 1200 lbs empty and will only have about 500lbs loaded in it when I do pull it and dont want to burn up the trans
Old 07-21-2008, 10:51 PM
Dealer : Harrelson Toyota
2006 Toyota Tacoma
Last Online: 02-08-2009 12:06 AM
tacomaman06 is on a distinguished road.
tacomaman06's Photo Albums
Default Re: Transmission cooler
im pretty most of the tacomas have a small cooler built in, but if you are gonna be pulling, you are on the right track. you need an auxiliary cooler installed. you can find them by perma-cool or b&m.....they both make good ones, and they are relatively easy to install, and they dont cost alot.. just remember...the bigger,the better, but you gotta make sure there is room for it. the other cooler you see is the oil cooler if im not mistaken. im also gonna get a cooler casue i plan i towing, and anyway to keep the tranny cool is a good idea.
Old 07-22-2008, 09:42 AM
barron64's Avatar
Dealer : Lynch Toyota of Auburn
2006 Toyota Tundra DC 4x4 SR-5,
1996 Toyota Tacoma LX Extra Cab 5-Speed
Last Online: Yesterday 09:51 AM
Images: 9
barron64 is on a distinguished road.
barron64's Photo Albums
You will be fine with the stock setup. I believe that model was rated to tow a 5K load so you are well below that. You already have a built in tranny cooler in the bottom of the radiator tank anyway. You can add an additional cooler in line if you really want but it is kind of a pain to do on that model. Not much room for the extra cooler or lines. I had an 04 DC 4x4 that I added an extra cooler to so I am speaking from experience.
Old 07-22-2008, 09:50 AM
2002 Toyota Tacoma
Yeah that is what I was thinking. If I have learned anything from having a Taco (and a 93 for 9 years and 300,000 miles on it) is that Toyota has got it covered. Why would they rate the truck to tow 5K load and not have the tranny to handle it. I expect that from Ford but not ToyotaThanks for the help to everyone
Old 07-23-2008, 01:56 PM
The Phoenix's Avatar
Moderator
Last Online: 11-13-2009 03:17 PM
Images: 2
The Phoenix's Photo Albums
Visit IPT Performance Transmissions Torque Converters and Transmission Parts for Ford, GM, Chrysler, and Import vehicles in Wayne. They can upgrade your valve body if you want. You will NEVER wear that sucker out. I'd go with the amsoil flush as well.
Old 07-23-2008, 02:30 PM
kathyricks's Avatar
Dealer : Capitol Toyota
1993 Toyota Truck
Last Online: 06-02-2009 12:03 PM
kathyricks's Photo Albums
To keep the transmission cool when towing, simply keep the transmission in Direct Drive
(3rd gear for a 4-speed transmission and 4th gear for a 5 speed transmission) and limit your speed to 55-63 MPH on the level and 45-55 MPH when going uphill. I agree with the others who say you don't need an extra cooler - you can see this for yourself by pulling the transmssion dipstick after 50 miles of towing in Direct Drive at 55 MPH - the fluid on the dipstick will likely be only warm, but not scalding hot.
Towing is overdrive is bad because the transmission will up and downshift more often and the torque converter clutch will unlock and lock more often = extra wear and heat. Towing in overdrive also usually increases fuel consumption.
Old 07-23-2008, 08:40 PM
Marazzito's Avatar
Dealer : Toyota 101
2007 Toyota Tacoma,
2006 Toyota Highlander HV,
- Other - 1967 TLC FJ40
Last Online: 02-15-2009 12:16 PM
Marazzito is on a distinguished road.
Send a message via AIM to Marazzito Send a message via Yahoo to Marazzito Marazzito's Photo Albums My eBay
5,000 lbs with the tow package which adds a tranny cooler. I believe it is only 3,500 with out!
2007 Tacoma DC 4x4 V6 TRD Off-Road
Supersprings
TRD Exhaust
AFE Cold Air Intake
URD Short Throw Shifter
TRD Supercharger (coming soon)
1967 Toyota Land Cruiser FJ40
Springover
Rear Detriot Locker
Front ARB Locker
Longfield Super Axles
SM420 Transmission
Orion 4.1 Transfer Case
Chevy 327 V8
Teraflex Revolver Shackles Rear
Trail-Gear Six Shooter Knuckles
37x14.00 Super Swamper Bias Ply Irok's
**Just to name a few**
2006 Highlander Hybrid
Chrome License Plate Frames, lol.
Dustin Marazzito
www.piffinancial.com
Old 07-29-2008, 09:27 AM
Arb1977's Avatar
Dealer : Gilroy Toyota Scion
2002 Toyota Tacoma
Last Online: 09-02-2009 05:05 PM
Arb1977 is on a distinguished road.
Arb1977's Photo Albums
First gen Tacos come with a auto tranny come with a cooler at the bottom as part of the radiator. I would add a secondary cooler on top of that. Non tow package Tacos are rated for 3500 lbs and tow package Tacos are rated for 5000 lbs. A way to tell if you have a tow package is look at the fan clutch the base will be green or orange. Green=tow package, orange=no tow package. The green fan clutch is alittle bit more heavy duty compaired to the orange clutch. Every Taco comes with a tranny cooler regardless if you have a tow package or not.
2002 TACOMA 3.4L 102K AND COUNTING
Old 07-29-2008, 09:35 AM
2002 Toyota Tacoma
Good info. I have the green ran clutch.
