Old 08-31-2008, 02:32 AM
Dealer : Mossy Toyota Scion
2009 Toyota Tacoma
Last Online: 08-31-2008 04:54 PM
Billinsd is on a distinguished road.
Billinsd's Photo Albums
Default tranny temp gauge questions?
I have a 2002 tacoma and had an autometer gauge installed. The tech said he conected it to the overtemp sensor? I got the truck home and get a trouble code p0710 that is a sending unit malfunction. Also, the temp has not gone above 100F and the tech said that the gauges barely move. Doesn't seem right?
Can you connect the gauge to the overtemp sensor?
I'm going to bring the truck back in, but I want to educate myself.
Thanks
Bill
Old 08-31-2008, 12:23 PM
HOGWILD's Avatar
Dealer : American Toyota
2006 Toyota Tundra,
1993 Toyota Truck,
2007 Scion tC
Last Online: Yesterday 02:50 PM
Images: 12
HOGWILD is a splendid one to behold. HOGWILD is a splendid one to behold.
HOGWILD's Photo Albums
Default Re: tranny temp gauge questions?
Post his picture here!! or better yet post picture of his work next to his picture! This should be good! Did he fix you MIL issue for ya?
Old 09-01-2008, 11:50 AM
Arb1977's Avatar
Dealer : Gilroy Toyota Scion
2002 Toyota Tacoma
Last Online: 09-02-2009 05:05 PM
Arb1977 is on a distinguished road.
Arb1977's Photo Albums
I installed the sending unit with a manifold block just before it enters the stock cooler.
2002 TACOMA 3.4L 102K AND COUNTING
Old 09-01-2008, 12:49 PM
HOGWILD's Avatar
2006 Toyota Tundra,
1993 Toyota Truck,
2007 Scion tC
Images: 12
what kinda temps ya getting not towing? or towing in Texas?
Old 09-02-2008, 07:22 AM
Arb1977's Avatar
2002 Toyota Tacoma
It verys... freeway driving alittle over 100 degrees, around town close to 180 degrees. This is without towing and with a TRD tranny cooler after the stock cooler. When i moved here at the start of summer towing about 4000 lbs with the tow package climbing mountain grades sometimes in second gear it got as high as 220.
This also taking temps before the coolers.
Old 09-02-2008, 01:52 PM
HOGWILD's Avatar
2006 Toyota Tundra,
1993 Toyota Truck,
2007 Scion tC
Images: 12
I have been looking at the Cyberdyne setups and might give them a shout to see if they can fit my Tundra with anything, they have some nice digital gauges and 2 or 3 group clusters. Idiot light and computers just do not do it for me. I was waiting till Scanguage did something with the tranny temp but they will not even answer my email so looking elsewhere! 220 is kinda high for ATF fluid i would check it really close for being burnt, color or smell!!
Old 09-06-2008, 10:16 PM
The Phoenix's Avatar
Moderator
Last Online: Yesterday 03:03 PM
Images: 2
The Phoenix's Photo Albums
I don't think the overtemp sensor was correct at all, if it even exists on the Tacoma. There should be a temp sensor that you could tap and that should be the right one.
Old 09-07-2008, 10:14 PM
Herbicidal's Avatar
Just a Herbicidal maniac.
2001 Toyota Tundra,
2008 Toyota Yaris Sedan 'S' Flint Mica,
2009 Toyota Corolla 'S' Barcelona Red
Last Online: Yesterday 11:43 PM
Images: 150
Herbicidal's Photo Albums
The most accurate location for the sending unit is in the tranny pan. I bought a 2nd pan and had the sending unit mounted inside, then swapped the old for the new. I have an Auto Meter 'A' pillar tranny temp gauge wired to it.
For the Tundra owners reading this thread, normal summertime (stop and go commute driving) non-towing temps on my Tundra are about 180 degrees. I'm running a larger aftermarket cooler with Amsoil in the tranny. I also installed a thermostatically controlled fan that kicks on at 180 degrees. This also helps to move the air when I'm wheelin on the trails and the speed is too low for good cooling air flow.
Towing our 26' Outback travel trailer (5,600 lbs) on the flats at 60 mph in the summer shows about 165-180. Going up a good long grade I've seen 225. I believe on the 1st gen Tundra's the warning light comes on @ 270. Regardless, I've never had the light come on. I now have over 125,000 on the clock and no problems! I love my Tundra!
