Originally Posted by maohaus
Hi folks, I own a 2003 4cyl Tacoma with 80,000 miles. I've faithfully replaced the oil and air filters at specified intervals, but haven't done much else. I plan on replacing the automatic transmission fluid and having a fuel injector/plugs tune-up. Aside from the timing belt at 90K I wondered if there is any other maintenance I should be looking into.
I beleave you have a timing chain since you have 4 banger. As far as injector service i wouldnt waste your money. What i do is buy some Lucas Upper Cylinder lubercant and add that to the gas every fill up...4oz worth. Not only does it clean the injectors, it keeps the upper cylinders lubercated along with the valves and rest of the fuel system. Plugs should be changed every 30K.
If its the same auto as the 3.4L you dont have a filter in the auto tranny, you have a screen. Simply drain whats in the pan and refill...do this maybe three times or at least till the fluid is bright red.
