Old 01-14-2009, 12:17 AM
Dealer : Priority Toyota
1997 Toyota Tacoma
Last Online: 05-30-2009 11:26 PM
Cobb is on a distinguished road.
Cobb's Photo Albums
Default v6, valve adjustment?
Do I need to get a valve adjustment in my v6 toy 97 model. I see in the manual how to adjust the valves on both the 4 and 6, but my service book does not list when to get them adjusted.
Thanks
Old 01-20-2009, 02:31 PM
The Phoenix's Avatar
Moderator
Last Online: 11-13-2009 03:17 PM
Images: 2
The Phoenix's Photo Albums
Default Re: v6, valve adjustment?
I'd say 150K at least they should be checked.
Old 01-20-2009, 10:55 PM
1997 Toyota Tacoma
Cobb's Photo Albums
Thanks. I am sure I am asking alot of idiot newbie questions, however search and the manual are little help. I did see a valve lash sticker under the insulation on the hood the other day and kind of concluded the tapping I hear and that ment it has valves that need adjusting.
Old 01-21-2009, 07:04 PM
kathyricks's Avatar
Dealer : Capitol Toyota
1993 Toyota Truck
Last Online: 06-02-2009 12:03 PM
kathyricks's Photo Albums
The factory manual advises checking the valve clearances, at least audibly, every 60,000 miles.
If some of your valve clearances are too loose then you'll hear a tapping / rattling like noise when the engine is idling, warm or cold. But if the noise you are hearing goes away after the engine is fully warmed up then the noise is NOT due to loose valve clearances, but from something else like a leaky exhaust manifold gasket.
Unexplainable engine vibration when idling could also mean some of your valve clearances are too tight. Loose valve clearances cause noise, but not engine vibration.
Old 01-21-2009, 11:36 PM
1997 Toyota Tacoma
Cobb's Photo Albums
I have either a rod or lifter click once warmmed up.
Now, when its cold out, driving 25mph I get a whistling noise like the alternator bearing or something, however the noise does not vary with engine rpms. Strange....
I think as soon as I get my refund from my taxes, going to get the dealer to flush the tranny, adjust the valves, then get a local performance electronic shop put in the alarm with remote start and 25-50 hp nitrous shot.
Old 01-22-2009, 02:41 PM
Dealer : Valley-Hi Toyota
2005 Toyota Tacoma,
1995 Toyota MR2 1991 Sunroof w/ 1MZ
Last Online: Yesterday 08:37 PM
Jason.MZW20 is on a distinguished road.
Jason.MZW20's Photo Albums
Are the 5VZ's lifters shim-over, shim-under, or shimless?
I have part numbers and sizes for shimless buckets if you want to be rid of the shims. The downside to shimless buckets is increased noise, and that's exactly what you're trying to be rid of.
2005 Tacoma Double Cab V6 4x4 w/ TRD Off-Road pkg., Auto
1991 MR2 V6 (1MZFE)
Old 01-24-2009, 11:27 PM
1997 Toyota Tacoma
Cobb's Photo Albums
Dont know the type, letting the dealer handle that.
You can kind of hear the clicking here YouTube - motor 97 tacoma v6
fyi, here is the muffler YouTube - trd tacoma muffler 97 v6
