Re: '01 Tacoma errors
Definitely not a gas cap problem. Bad HO2S would throw other codes. MAF wouldn't throw an insufficient coolant temp sensor.
This almost sounds like a stuck open thermostat. As mentioned, we need the actual codes (P0xx) rather than a description. It could also be a bad coolant temp sensor. Again, if we knew what the codes are we could narrow it down greatly. Some codes are set when the temperature doesn't rise a certain amount in a specified amount of time (thermostat monitor). If the ECT is bad, it could possibly not register change and set the code.
Again, we need all the Pxxx style codes.
2004 Marlin Blue Pearl Sequoia SR5 2WD; 60k miles
1991 Isuzu Trooper 2.6L 5spd 4x4; 103k miles
1993 BMW 525i M50TUB25 auto; 286,500 miles
ASE Certified Brakes Technician / Automotive Electrical Specialist
Independent BMW Technician
