Re: Removing door windows or door panels
Though I've never done it on a tacoma, as long as the glass is off the acuator then the glass should come out once the gasket is removed. Just make sure the glass doesn't have 2 areas that are holding on. In other words their are 2 bolts on the regulator holding the glass, just making sure you knew that. On the windows I have removed some had to have the rubber gasked removed, some of these were bolted on at the windows edge, right below were you arm would rest when riding down road with window down. Man do I ever need a digital camera. Don't forget ,no shame to google it, just don't get spamed.
